Tecumseh 4 1/2 Hp Question
3 replies to this topic
#1 Alc ONLINE
  • 6,744 Thanks
  • 7,397 posts
Posted June 23, 2014 - 08:56 PM
My bosses son is working on an old Craftsman  131.8220  rider  one like was posted here back in 2012
http://gardentractor...uestions/page-3
the motor #  is 143.105011  Serial 0661178  he's having a problem trying to figure out how to remove what's under the flywheel some type of block on the crankshaft  keeping them from getting the cover for the points off . .I can't picture what he's talking about . Could the flywheel have come apart ?
#2 MH81 OFFLINE
Posted June 23, 2014 - 09:03 PM
Al, you got me buddy. Never heard of such a thing.
Can they take pics, eliminate translation issues?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted June 23, 2014 - 10:41 PM
Sounds like a flywheel key or a points cam to me.  Both can be a bit stubborn.  The flywheel key is best removed with a pair of vice grips to act as a puller.  I made a special cam puller for my engines, it grabs at the base like a miniature gear puller so you don't screw it up pulling it out.  The points cam is under the points cover.   The only reason I mention it is because the little aluminum cover should slide right over the flywheel key, so I don't know what a key would stop him.
The 143-105011 model number is not a good model number for my old cross reference.  They start at 122xxx.
Ben W.
#4 Alc ONLINE
  • 6,744 Thanks
  • 7,397 posts
Posted June 24, 2014 - 05:19 AM
I'm going to see if he can email a picture,, for the life of me can't figure out what it could be
