Ford Lgt 14D $800 Runs
5 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 2,965 Thanks
  • 2,318 posts
Posted June 23, 2014 - 07:15 PM
this is too far or I'd snatch this up if it's still there.
http://martinsburg.c...4525664626.html
  • EricFromPa and boyscout862 have said thanks
#2 Rock farmer ONLINE
Rock farmer
  • 1,128 Thanks
  • 1,183 posts
Posted June 23, 2014 - 07:49 PM
I'd get just to be the only kid on my block with a three cycle engine!
I wonder how that works?
  • TomLGT195 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 2,965 Thanks
  • 2,318 posts
Posted June 24, 2014 - 03:59 AM
didn't notice that, thats funny
  • Rock farmer said thank you
#4 KennyP ONLINE
  • 30,503 Thanks
  • 41,076 posts
Posted June 24, 2014 - 05:35 AM
Pretty good looking tractor!
#5 JDBrian OFFLINE
  • 9,592 Thanks
Posted June 24, 2014 - 06:28 AM
Don't see those often and usually not for such a low price.
#6 EricFromPa OFFLINE
EricFromPa
  • 2,540 Thanks
  • 2,471 posts
Posted June 24, 2014 - 03:19 PM
Engine Detail:   Shibaura   diesel   3-cylinder   liquid-cooled   617 cc [37.7ci ]   Bore/Stroke: 2.5x2.5 inches [64 x 64 mm] Power (gross): 14 hp [10.4 kW] Air cleaner: dry Pre-heating: block heater (optional) Starter: electric Starter volts: 12 Oil capacity: 2.7 qts [2.6 L] Coolant capacity: 2.7 qts [2.6 L]
Dimensions: Weight (shipping): 1,005 lbs [455 kg] (with 48" deck) Wheelbase: 47.2 inches [119 cm] Length: 71 inches [180 cm] Width: 39 inches [99 cm] Height (steering wheel): 47.6 inches [120 cm] Ground clearance: 6.2 inches [15 cm] 2WD turn radius: 2.6 feet [0.8 m]
It's a Heavy little fella.Bet it's a bear to turn without power steering.
