Wonder If He'd Trade For A Hooked On Phonics Set?
6 replies to this topic
#1 MH81 OFFLINE
  • 29,979 Thanks
Posted June 22, 2014 - 07:44 AM
Or maybe a used encyclopedia set...
I suck at spelling, but I know it and use spell checker.
http://youngstown.cr...4461969319.html
9 proffetional equitment gym - $2000 (3337 powers way)
1 bench with profetional disc or weigh 300 pound on weigh 2 profecional bars 1 straing one curve 4 dombers
2 cread treat mill almost brand new buy it in sears for 3.000 dollar
3 machine for your bicets andtricet
4 machine for you butt and abs
5 macgine that hold you upside down
another mmachine for the site of you stomach
any question contact mewas use everything for1 month I spend 15000 dollars on all the equitment you need a pick up truck to get it phone is show contact info f u want me to send it over will be a lot cause is to much weight
  • sacsr and Sawdust have said thanks
#2 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted June 22, 2014 - 07:55 AM
Wow! I'm thinking that ad had so many errors spell check said screw this I'm out of here!! :rolling:
  • MH81, GTTinkerer, KennyP and 1 other said thanks
#3 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,311 Thanks
  • 10,287 posts
Posted June 22, 2014 - 08:33 AM
You should be ashamed!!!  Quadra-plegics use CL, too.
  • MH81, pigsitter and Sawdust have said thanks
#4 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted June 22, 2014 - 08:58 AM
Ads like this fascinate me. This one is probably the worse I've seen. Like LD mentioned we have to be careful with our criticisms. Most of his (assuming male) letter choices are nowhere near what he should have typed. I want the macgine that holds you upside down...might be interesting. :D
  • pigsitter said thank you
#5 ckjakline OFFLINE
ckjakline
  • 1,148 Thanks
  • 1,139 posts
Posted June 22, 2014 - 09:11 AM
Huked on fonicks worked fur me.
  • KennyP, pigsitter and Sawdust have said thanks
#6 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,311 Thanks
  • 10,287 posts
Posted June 22, 2014 - 12:38 PM
There was a guy on YTF(your tractor forum) that I figured was either foreign or not too bright. His English was really broken. After a couple of years, I finally found out he was deaf.
  • Sawdust said thank you
#7 grnlark OFFLINE
grnlark
  • 340 Thanks
  • 375 posts
Posted June 23, 2014 - 06:16 AM
I bet that's on purpose. Its probably someone messing around
