1107 Update
5 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 21, 2014 - 10:10 PM
Many of u know about my 1968 1107 I got a while back and put new sheet metal on that I got off thecookiemonster. Well I havnt been on here for a while and the tractor has gone through a ton of changes. First off I did a mild engine build. I port and polished the intake and exhaust ports, modifed the intake tube, put a 10hp carb on it, shave the cylinder head, and shaved the eyebrows. And of course custon header and air cleaner.
The tractor it self needs a lot of work. The rear axle nut threads are now missing so I got a tube with set screws holding brake and tire on, and the rear end leaks a ton of oil. Other than that she looks about the same.
  • Dieselcubmike and panzersarebest have said thanks
#2 MH81 OFFLINE
Posted June 21, 2014 - 10:50 PM
Did the engine build up make a difference?
#3 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 23, 2014 - 07:45 PM
Yes it did. I built it mainly for pulling. I have I run it on 93 octane or above. Throttle response got way quicker, also torque came up a ton.
#4 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted June 28, 2014 - 11:48 PM
That thing did run rough, I remember.  I ain't been on much either...  Glad to hear that it's coming along.  There was a post on here about serial numbers... I wonder if that sheet metal has the serial number for that 1107 I parted out...
#5 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted July 03, 2014 - 01:50 PM
Yes it does would u like me to send them to u
#6 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 04, 2014 - 10:09 PM
Nah.  I have all the t70 tags and my spare parts got sold.
