To Ag Or Not To Ag( Tires)
17 replies to this topic
#16 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted June 22, 2014 - 07:13 PM
i'm going to go to a set of snowblower tires on the EK this winter from the standard mostly worn out firestone turf/traction tires that were on it when i got it and have to air up everytime i use it
#17 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted June 23, 2014 - 11:28 AM
I've used both ag's and turfs for mowing both were fine.
#18 T Guiles OFFLINE
T Guiles
  • 956 Thanks
  • 749 posts
Posted June 23, 2014 - 12:07 PM
Buy what YOU want, Ag's look cool and work well, turf's also work very well.  IMHO you could put a set of chain's on a completely bald tire and with in reason, would have NO problems. I have a ford lgt 165 with ag's on it that I use to mow with and never had problems with chewing up the lawn, I also have a 165 with turf's on it ,chain's and weight's, that I plow snow using a 54 inch plow. The only time I've been stuck is when I pushed a little too far a put the front tire's in a ditch. Call me cheap but I only buy tire's when the air comes out faster than i can put it in, but when I do it'S AG'S....They just look so much cooler      Thank's and good luck in your choice
  • propane1 said thank you
