My Ford 100
64 replies to this topic
#31 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted January 29, 2017 - 02:53 PM
I'm stuck on this: what is supposed to be holding the deck-height adjust lever assembly onto the frame bar? This hole is threaded on the inside, but if that's a set screw in there, it is totally flattened on top. Might have to drill it out? Any advice?
#32 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted January 30, 2017 - 02:22 PM
i think mine has a bolt with a square head on
  • backwoods said thank you
#33 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 01, 2017 - 08:44 PM
That's what the one had I'm working on I got the bolt/ set screw out, then with a lot of pb blaster a big hammer an a pipe I slowly started hammering it off
Sent from my SM-S820L using Tapatalk
#34 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted February 09, 2017 - 08:32 AM
I drilled it out without harming the threads and was able to tap the assembly off the bar. The frame is totally stripped now, waiting for warmer weather to paint and begin reassembly.
#35 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted February 19, 2017 - 04:02 PM
Progress...
Not sure why all these pics are in landscape orientation. They're portrait on my PC. Any way to change that?
Edited by KennyP, February 19, 2017 - 04:20 PM.
Adjust Gravity
#36 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted February 19, 2017 - 04:21 PM
Did you take those with a phone? That's where they usually rotate as they want.
  • Joe Knife said thank you
#37 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted February 21, 2017 - 08:04 AM
Yeah with my phone. But I see now that they are correct in the actual post--just sideways in the attachment box at bottom. That's fine!
#38 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted February 21, 2017 - 08:16 AM
Yeah, I rotated them.
  • Joe Knife and 29 Chev have said thanks
#39 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 26, 2017 - 09:35 AM
your farther then me right now its looking good though i cant wait for it to warm up so i can spray the white since i already have that.
#40 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted March 06, 2017 - 02:57 PM
2 questions:
1. What's the best way to remove these ball joints / tie rod ends? When I put the rod in a vice it just turns. I've tried wrapping it with rubber and steel wool and neither one worked. If I grip the other end in the vise, seems like the rod will twist or bend before the threads give. Kinda stuck on there.
2. This little hole in the brake pedal assembly--am I missing a grease nipple here? Or is this just maybe a hole to drip some oil in?
Thanks,
Joe
Edited by Joe Knife, March 06, 2017 - 02:57 PM.
#41 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted March 06, 2017 - 05:07 PM
2 questions:
Thanks,
Joe
Can't help on the brake assy! Did you back the locking nut off before trying to unscrew the tie rod end? May need some heat to break it loose.
#42 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted March 06, 2017 - 05:26 PM
Are the nut and the end separate pieces? I thought there was just a hex face on the end of the ball joint assembly.
Edit: Upon learning there's a separate locking nut I was able to get 3 out of 4 removed. Last one still being a pain but soaked with more Deep Creep and will give it more time. Thanks!
Edited by Joe Knife, March 06, 2017 - 05:49 PM.
#43 MM MARK OFFLINE
MM MARK
  • 77 Thanks
  • 36 posts
Posted March 06, 2017 - 08:49 PM
The hole is to drip oil in
  • KennyP and Joe Knife have said thanks
#44 Joe Knife OFFLINE
Joe Knife
  • 117 Thanks
  • 118 posts
Posted March 07, 2017 - 03:42 PM
Got the last rod end off and found what looks like an exact replacement:
https://www.mcmaster...58k271/=16nl0aj
#45 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted March 07, 2017 - 05:06 PM
That's great news! Have fun!
