Weak Spark
4 replies to this topic
#1 Tomwendt ONLINE
Tomwendt
  • 129 Thanks
  • 142 posts
Posted June 21, 2014 - 02:19 PM
i have a 14hp briggs cast with a weak spark.it has a starter generator.i want to add a coil.anyone have a wiring diagram they could post? thanks
#2 MH81 ONLINE
  • 28,902 Thanks
  • 29,273 posts
Posted June 21, 2014 - 03:28 PM
Have you tried a new condenser? You might be able to even put it in parallel with the kill wire just to test.
Worth a try anyways.
  • trowel said thank you
#3 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted June 21, 2014 - 03:46 PM
Yes, a external coil can be used instead, simple to hook up but a coil with a internal balance resister must be had or it will burn out the points.
I am under the impression this Briggs cast iron is in a Simplicity Sovereign ? as stated above you might check or swap out the condenser.
Try this also :
Spark plug gap - .025
Breaker points gap - 16 to 18
  • MH81 and superaben have said thanks
#4 propane1 ONLINE
propane1
  • 7,132 Thanks
  • 3,575 posts
Posted June 21, 2014 - 06:05 PM
Condenser needs to have a good ground. Make sure engine to frame of tractor is good too. Any bad connection will cause bad spark. Noel
#5 Tomwendt ONLINE
Tomwendt
  • 129 Thanks
  • 142 posts
Posted June 21, 2014 - 06:39 PM
thanks.ill get on it in the morning and get back
