Bolens G8 Home
20 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1479 Thanks
  • 676 posts
Posted June 21, 2014 - 11:40 AM
I bought this g8 at an auction today. That bad is its got a broken axle. Anyone know what transaxle it uses? The good it came with a blade and wheel weights. It doesn't look like the blade was ever used much. Are the weights bolens or after market?
  • OldBuzzard said thank you
#2 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6893 Thanks
  • 4615 posts
Posted June 21, 2014 - 03:42 PM
Peerless Model 623 and 623A transaxle.Also known as the Peerless 600.
They are a very heavy built transaxle for they're size.I used to use them in all my Go-Fast tractors when I was a bit younger.
Manual for the G8.
http://gardentractor...01-thru-813-03/
Looks identical to the 3 speed peerless transaxles used in alot of the smaller Wheel Horse and earlier MTD built Lawn Tractors.
Wheel Weights look correct for the Small frame Bolens.It's really hard to tell though without some casting numbers.
Edited by EricFromPa, June 21, 2014 - 03:57 PM.
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted June 21, 2014 - 07:56 PM
:ditto:
On the Peerless
The weights are original from what I can tell, if not they should fit some of the newer LT series Bolens as well.
#4 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 02:44 PM
I have a bolens g8 as we'll hand I need to order parts for it and have no clue were
#5 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 18, 2014 - 04:07 PM
What parts do you need, I have quite a few instock.
#6 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 05:49 PM
Gas tank, muffler, carb repair kit, mower deck brackets to hold up deck and air filter and thanks for responding
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 18, 2014 - 06:53 PM
Below is a partslist for your machine
What model & type Briggs is on this?
Should be able to help you with everything but the Tank, and possibly brackets
#8 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 07:20 PM
Model 813 Briggs and Stratton 8hp motor
#9 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 07:40 PM
Model 813 and a 8ho Briggs
#10 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 18, 2014 - 08:14 PM
Looking for the actual model of Briggs like the 191707-  (Type)
#11 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 09:17 PM
It a 191707 Briggs and Stratton engine
#12 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 09:18 PM
I don't know what type tho
#13 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 09:43 PM
4 cycle, single cylinder air cooled
#14 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Posted July 18, 2014 - 10:52 PM
Engine Detail:
    Briggs & Stratton 191707
    gasoline
    1-cylinder
    air-cooled vertical shaft
    318 cc [19.44ci ]
#15 Bolensg8fan OFFLINE
Bolensg8fan
  • 11 posts
Engine Detail:
    gasoline
    1-cylinder
    318 cc [19.44ci ]
