Oil Drian Plug/cap Wont Fall Out Now, Hopefully
3 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,723 Thanks
  • 4,130 posts
Posted June 19, 2014 - 05:46 PM
Welded a nut to the 1/4" nipple. Put a little longer nipple in so it will be easier to get at the cap to get it off and oil will drain into oil pan not all over the front axle. Now I can tighten the nipple easier and make sure it is tight, then I can hold the nipple and put the cap on and tighten it while I hold the nipple from moving and the same when removing. Pressure tested the nipple after welding nut on to make sure of no leaks there.  Hope it works.  Noel
And it runs.
Edited by propane1, June 19, 2014 - 06:05 PM.
  • MH81, trowel, New.Canadian.DB.Owner and 3 others have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted June 19, 2014 - 05:57 PM
there you go :D looks like it will work just fine :thumbs:
  • Gabriel and propane1 have said thanks
#3 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted June 19, 2014 - 07:11 PM
Looks like it will hold. Apparently the cap was used to tighten the nipple into the engine. That won't work! Have to tighten the nipple in, then put the cap on with less force!
#4 MH81 OFFLINE
Posted June 19, 2014 - 08:19 PM
They do make a locknut for pipe thread, that might help too.
Nice fix, looks like it'll hold.
