Gas Tank Restoration
9 replies to this topic
#1 R C OFFLINE
R C
  • 4 Thanks
  • 9 posts
Posted June 18, 2014 - 06:44 PM
Have a few pinholes in a Ford 100 gas tank, any products to line the inside that works??
  • Gabriel said thank you
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted June 18, 2014 - 06:48 PM
I use Red Kote.
After cleaning the inside fill the pin holes with JB weld, let dry, sand it down and coat insides, let set up for a week and paint the tank.
Welcome to GT Talk, glad you joined.
Edited by trowel, June 18, 2014 - 06:48 PM.
  • Bolens 1000, JDBrian, R C and 3 others have said thanks
#3 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 18, 2014 - 07:28 PM
Another product is Por 15
http://www.por15.com...ation_c_17.html
For my 165 tank, I cleaned the exterior as well as I could, and soldered a piece to the bottom of the tank.
I had to be careful since the tank is made from three pieces soldered together.
  • JDBrian, trowel, R C and 2 others have said thanks
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 18, 2014 - 07:36 PM
I have used a large soldering iron (85w) to fill pin hole in tanks.  Takes a lot of patients & slow movement, but it will eventually work.  Can't do it with a torch, has to be an iron.  Oh, and you will need flux.  Lots of flux.
#5 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 18, 2014 - 08:57 PM
I use Red Kote.
:ditto:
Been using that stuff for years and have never had any more leaks after that!
  • JDBrian, trowel and R C have said thanks
#6 HANKG OFFLINE
HANKG
  • 6,320 Thanks
  • 3,425 posts
Posted June 19, 2014 - 06:37 AM
BILL HIRSCH AUTO PRODUCTS GAS TANK SEALER ETHANOL/ALCOHOL RESISTANT WORKS GREAT.
  • R C said thank you
#7 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,175 posts
Posted June 19, 2014 - 07:03 AM
Where can I get Red Kote? I've got atleast 6 tanks to do. Good Luck, Rick
  • trowel and R C have said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 19, 2014 - 07:45 AM
:welcometogttalk:
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted June 19, 2014 - 10:06 AM
Napa Auto Parts. POR 15 also.
  • R C and boyscout862 have said thanks
#10 R C OFFLINE
R C
  • 4 Thanks
  • 9 posts
Posted June 19, 2014 - 11:27 AM
Hey Guys, thanks loads, this is a great site, will use this again,  Ron from Ferndale, WA
