Jd 318 Barn Find
318 john deere 318 jd tractor
19 replies to this topic
#16 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted June 22, 2014 - 05:21 PM
Harlan,
Thank you, I think that this in sufficient information!
alec:
I remembered I had taken a picture of mine for another member. He needed the directions on it to know how to loosen and tighten the belt. I looked around a little and found it.
Harlan
#17 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted June 26, 2014 - 11:04 PM
I went & took a good look at it today... I found both side engine covers....yay ... all is there.... sat for a couple years with old gas in it... I made an offer for the $200 cash but the mowing option is still on the table.... lots of paint wore off but actually pretty straight & not all rusted out... pretty good but ugly condition. I will get pictures on Saturday as I forgot my camera.....deck & blades are in great shape
Edited by howard H, June 26, 2014 - 11:07 PM.
#18 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted June 28, 2014 - 05:46 PM
ok, got pictures of the JD 318.... needs 1 tail light, other parts are scattered around it..... can you say crusty....it did run good when parked  & the hydraulics worked...................................................................................................................................................GEDC3610.JPG GEDC3611.JPG GEDC3612.JPG GEDC3613.JPG GEDC3614.JPG GEDC3617.JPG GEDC3616.JPG GEDC3615.JPG .
Edited by howard H, June 28, 2014 - 05:48 PM.
  • oldedeeres and superspeedex have said thanks
#19 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted June 28, 2014 - 06:04 PM
ok, got pictures of the JD 318.... needs 1 tail light, other parts are scattered around it..... can you say crusty....it did run good when parked  & the hydraulics worked...................................................................................................................................................attachicon.gifGEDC3610.JPGattachicon.gifGEDC3611.JPGattachicon.gifGEDC3612.JPGattachicon.gifGEDC3613.JPGattachicon.gifGEDC3614.JPGattachicon.gifGEDC3617.JPGattachicon.gifGEDC3616.JPGattachicon.gifGEDC3615.JPG.
Yes, but will it run now?  I wonder why the engine covers are off it. For 200 I think it's worth the risk.
  • howard H said thank you
#20 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted June 28, 2014 - 06:11 PM
going to have to go through the fuel system & clean it out... the motor turns by hand & not frozen up... good sign... the guy I got it from got it from the pawn shop he worked at.... they got rid of tons of riding mowers but gave him this tractor & it did run when they got it., no one wanted to buy it... hope all will be good... well worth the $200...he did try to get it running, reason for covers being off but it had old, old gas in it....only way to find out is put a hot battery on it & throw some fresh gas down the throat of it & crank on it....
Edited by howard H, June 28, 2014 - 06:14 PM.
  • oldedeeres said thank you
Also tagged with one or more of these keywords: 318, john deere 318 jd tractor
