This Ever Happen To Any Of You ?
15 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,132 posts
Posted June 17, 2014 - 05:39 PM
 This is an engine I just put together two weeks ago. Was having a lot of trouble with not having any power and over heating badly.  14 hp kohler.  So tonite found out the points had closed from the setting I had them at. Reset them to proper setting, adjust the carb and went and cut some grass. Wow did it ever work better. Push on the hydro and the power would set you back in the seat. I figured, great its fixed, then all of a sudden I saw smoke from the front of the engine, so got off and oil every where. First thought was front oil seal, then broken block, then realized it was gushing out and shut of engine. Drain plug fell out.  Why do these things happen to me.   Noel
Needed to change the break in oil any way, I guess, and wont have to cut the grass there for awhile. Hot oil!  Good thing no environment people around!!
  • MH81, KennyP, sacsr and 8 others have said thanks
#2 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Posted June 17, 2014 - 06:09 PM
Hey! Another one of Me!!  Thought I was only mechanical guy with gremlins and hexes on the stuff I work on!  Couldn't be MY errors, someone must be messing with us, right? :D
  • KennyP, tinbender7, New.Canadian.DB.Owner and 5 others have said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted June 17, 2014 - 06:26 PM
Not the oil plug , but I get gremlins no matter how much planning and checking I do . Always overlook something.
  • KennyP, tinbender7, oldedeeres and 1 other said thanks
#4 IamSherwood OFFLINE
  • 8,391 Thanks
Posted June 17, 2014 - 06:38 PM
That's unfortunate. I hope you caught it in time.
Why would it have smoked? Was the PTO clutch throwing it at
the exhaust?
  • tinbender7 and propane1 have said thanks
#5 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted June 17, 2014 - 06:46 PM
Your doing better than me. I'd a never found the thing after it fell out. Good thing you noticed what was going on and now the fix is easy.
#6 KennyP ONLINE
  • 38,476 Thanks
  • 45,969 posts
Posted June 17, 2014 - 06:52 PM
I hope you caught it in time to save the engine! Grass will grow back, may be a while though!
#7 Sawdust ONLINE
Sawdust
  • 5,678 Thanks
  • 3,381 posts
Posted June 17, 2014 - 07:20 PM
Hope it's just a loose drain plug fell out.
#8 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,132 posts
Posted June 17, 2014 - 08:26 PM
Yes , had temporary muffler on for a test to figure out why it had no power. But the exhaust was not the problem. Oil went all over the front and muffler. Had the grill, bonnet and side panels off at the time. Noel I did make sure the drain plug was in and tight when I put the engine together.
Edited by propane1, June 17, 2014 - 08:29 PM.
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted June 17, 2014 - 09:09 PM
time to change the drain plug bearing!!!
  • MH81, Utah Smitty, pigsitter and 1 other said thanks
#10 MH81 OFFLINE
Posted June 17, 2014 - 09:59 PM
Or at least get it aligned. :rolling:
Glad it was caught early and with probably no side effects.
  • Utah Smitty, superspeedex and propane1 have said thanks
#11 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 17, 2014 - 10:07 PM
If it was turnin when you shut it down, chances are it's gonna be ok. To get smoke takes oil movement, that means something has to move the oil around. If there is oil to move around, then oil is getting sloshed ALL over inside too. Ya see, the only reasons for more oil than you think would be needed inside are for, cooling, and lube, thats it! If it were to stop turning, NO LUBE, thats BAD, means no lube, or gor got really hot. I be a bettin man, you put her back together, and you will be fine!
Edited by stiemmy, June 17, 2014 - 10:08 PM.
  • Chopperhed and propane1 have said thanks
#12 oldedeeres OFFLINE
oldedeeres
  • 9,530 Thanks
  • 4,776 posts
Posted June 17, 2014 - 11:55 PM
Brake out the Dawn liquid detergent, it'll clean up the mess on the tractor; what happens to the grass--- stays on the grass,  lol.
  • pigsitter and propane1 have said thanks
#13 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 18, 2014 - 06:41 AM
As far as happen to me?  Yup but not quite the same.  Bought a new 5 hp B&S to put on a customers log splitter, mounted it and fired it up, ran fine for about 30 seconds and died real fast.  Put on a new engine and remember to put oil in the second one.  Had lots of good fairly new parts though.
  • propane1 said thank you
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted June 18, 2014 - 06:51 AM
You didn't run over the drain plug with the blades cutting it in two. The pieces didn't get thrown at your car's windshield, etc..
See! Your getting better at this.
#15 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted June 18, 2014 - 06:59 AM
When pulling the Sears Roto Spader out of storage i tipped it forwards and dragged it out, loaded on to trailer and brought down to the shop, looked back and seen a trail of oil, apparently when i tilted the tiller forwards i snapped of the the pipe for the sump drain, needless to say the broken end came out ok and now had a drain plug in it but the was a heck of a spill to clean up off the barn floor.
