Gas Tank Dents?
16 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted June 17, 2014 - 12:32 PM
Does anyone have a clever way to remove dents from an engine mounted gas tank?
#2 MH81 OFFLINE
Posted June 17, 2014 - 01:07 PM
Picture?
If the tank can be pressurized, sometimes you can pop them out, assuming no creases.
Just make sure to set the regulator low, a pressurized canister can rupture and hurt you.
  • Alc and HDWildBill have said thanks
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 17, 2014 - 01:10 PM
Depending on the dent sometimes a suction cup will work.
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,755 Thanks
  • 4,246 posts
Posted June 17, 2014 - 02:01 PM
Picture?
dangerous!
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted June 17, 2014 - 02:46 PM
103_9886.JPG Not a good photo
#6 MH81 OFFLINE
Posted June 17, 2014 - 03:23 PM
Nope, those are creased on the edges.
Best i can see, If you can't open it up to knock them out, you're filling them in.
dangerous!
When I say pressurize, I meant low pressure, not high pressure.
Original post edited.
  • jd.rasentrac said thank you
#7 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted June 17, 2014 - 04:06 PM
I solder washers on edge and pull them out with a slide hammer with a hook on it. A stud gun (spot welds small nails on the surface) from Harbour Freight is usually in the $100 range so if you are going to do a few of them then that is an option.
Just get the tank somewhere close and them bondo the surface smooth.
  • sacsr and HDWildBill have said thanks
#8 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted June 17, 2014 - 04:20 PM
I had a gas tank that leaked....I washed it out several time then lit the torch to braze the leak.
There was still fumes in the tank and when it exploded, it took all the dents out!
  • KennyP and pigsitter have said thanks
#9 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted June 17, 2014 - 05:31 PM
I have not done it,you can heat the tank up and the ends are soldiered on, take them off and pound out the dents and put back
on
#10 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 17, 2014 - 08:03 PM
   Ever seen a shoe being fixed?  Picture the block they use to hold the shoe, now make it out of  a heavier piece of metal and mount it in a vice.  now slip the tank over the horn thru the filler neck, use a very small hammer and tap around the dents, keep working till your dents are gone :thumbs:
                                             Pete
#11 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted June 17, 2014 - 08:56 PM
I'd drill a small hole in the center of the deepest dents, insert a heavy threaded screw, and then try to pull out as much as you can using the claw end of a hammer. When you have the dents out as best you can, fill the holes with JB Weld and file smooth. Fortunately for you, it appears that the deepest dent is located more towards the top of the tank. so if you do get a leak, it won't drain the whole tank.
Good Luck to you, and keep us posted on the method you use.
Edited by johndeereelfman, July 02, 2014 - 06:40 PM.
  • HDWildBill and WHdbJD have said thanks
#12 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 18, 2014 - 05:30 AM
I was thinking maybe those " paintless dent "  tools might work but  the gas tank might be too thick of metal .  The guys that are good with them are just amazing on what you would swear needs to be filled , ground , painted ect .
#13 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted June 18, 2014 - 07:00 AM
Your all scaring me. This is beyond my ability. I'll live with it until I find a fresh one.
#14 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,755 Thanks
  • 4,246 posts
Posted June 18, 2014 - 07:04 AM
Best i can see, If you can't open it up to knock them out, you're filling them in. When I say pressurize, I meant low pressure, not high pressure.
yep, I know. We've made a car gas tank round - and we handled cautiously, too!
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted June 18, 2014 - 07:24 AM
Is a cherry bomb low or high?
