Put My B7100 Through The Paces
kubota b7100 hst 4wd backhoe front end loader fel b/h
19 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 16, 2014 - 10:19 PM
I bought this 1992 Kubota B7100HST-D a couple weeks ago after looking for several months for the "perfect" compact tractor (Hint: It doesn't exist).
However, the Kubota seemed to be a good buy...front end loader and backhoe, 4wd, HST, fairly low hours (850).
I got it home and took it over to a friends to help him level up his backyard--He had brought in a bunch of fill dirt so level out a badly sloping yard, but it ended up looking like the hills and vales of Disney's Matterhorn ride.
Add to that he has more stuff crammed in his backyard than I have in mine... believe it or not...
Anyway, we got down to work by me working to level a large mound of dirt that had been in place for 5 or 6 years... plenty of stuff in the way, including a Toro 223D mower, several David Bradley tractors and implements, and various and sundry items from IHC Cubs, Gravelys and you name it.
I started out by scooping dirt out of the pile and dumping it into low places in the yard so I could move around with out having my teeth jolted out of my jaws.
B7100 Back Draggin' 2.jpg B7100 Back Draggin' 4.jpg B7100 Back Draggin' 6.jpg --BTW  Does anyone know what the two upright pins on the top of the loader are used for? The have a hole in them for a hairpin.  There's also a hole on each side face at the top, and a nut welded to the top of the loader that is in line with the hole. A 1/2" x 13 tpi bolt will screw in about 3 turns, but it's actually a 12mm metric thread--not sure of the pitch.  Anyway, if anyone can enlighten me on what this is used for, I'd appreciate it.
It took a little while for me to get the hang of things, but pretty soon I was whittlling down the pile until a mountain had been made into a molehill.... well maybe two or three molehills....
IMG_20140609_180251_369.jpg IMG_20140609_180254_858.jpg IMG_20140609_180306_421.jpg
Here are some pics of some of the "treasures" in his yard--
I've forgotten the name of this little dozer, but it has a Wisconsin engine with vertical twin cylinders, a T92 transmission a'la Power King, and real wet steering clutches.  It puts the Struck dozers all to shame... it's for sale, but I'm not sure it can be easily moved right now as the T90 tranny's were bad about collecting water if the shift lever didn't have a seal over the top of it where it goes into the top housing.
IMG_20140606_143117_722.jpg IMG_20140606_144449_048.jpg IMG_20140609_175334_746.jpg IMG_20140609_175405_039.jpg IMG_20140609_175422_625.jpg IMG_20140609_175521_795.jpg
A Gravely 5200 with numerous attachments, including a regular tiller, a Rota-Hoe?, a tool plate, cultivator, and snow blade (partly seen), etc.
IMG_20140609_171529_824.jpg IMG_20140609_171643_087.jpg IMG_20140609_172043_286.jpg IMG_20140609_172518_695.jpg IMG_20140609_172602_023.jpg
A home made towable backhoe with a 5 hp gas engine.
IMG_20140609_173820_132.jpg IMG_20140609_173836_122.jpg IMG_20140609_173844_125.jpg
Numerous David Bradley tractors and implements and other miscellaneous "stuff"...
IMG_20140609_174116_401.jpg IMG_20140609_174158_551.jpg IMG_20140609_174232_052.jpg IMG_20140609_174336_582.jpg IMG_20140609_174452_739.jpg IMG_20140609_175804_109.jpg IMG_20140609_175841_280.jpg IMG_20140609_175944_750.jpg
Anyway, it was a good day's work and I really appreciated my little machine.
One sour note on the whole deal....
I took the machine to the car wash after working it (the engine was cool because I had just driven 40 miles with it), then offloaded it into my yard.  A couple days later I was checking things out to familiarize myself with it when I pulled on the black, stepped grass screen in front of the radiator.  It was loose and I was way upset when I saw dried grass packed in between the radiator and oil cooler so thick I had to dig it out with a stick... PLUS, just about every opening in the radiator was clogged.... Grrrrrr!!!!!!!  The dealer I bought it from said he would service it before he delivered it to me... I assumed (silly me) that that would include checking out the grass screen and radiator, but maybe not.
 I carefully cleaned all the grass out, then gently brushed the radiator fins with the edge of a metal brush to break up the caked-on dirt and grass--pretty much the same stuff as the adobe that people used to make into bricks for home out here... mud and grass dried and packed into wooden forms. I then blew compressed air through the radiator from the fan side--- a LOT of dust and dirt came out... this really makes me upset since the dealer, or at least the dealer's mechanics, and the PO, didn't do rudimentary PM as least as far as the grass screens go.  These little machines don't have a water pump--the cooling is through the thermo-siphon principle--hot water rising in the radiator is cooled and flows into the engine and the process repeats itself.
Anyway, I hope nothing serious has happened as a result of this.
FWIW,
Smitty
Edited by Utah Smitty, June 16, 2014 - 10:25 PM.
  • MH81, tinbender7, David Brown and 3 others have said thanks
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 16, 2014 - 10:44 PM
Neat Smitty. On the radiator I have started blowing mine out every 4 hrs. Dandelion fuzz will totally block the screen in that length of time. that dozer sounds interesting the Seabees had a little guy like that that could be air dropped into the south pacific islands to build air strips during WWII.
Edited by JD DANNELS, June 16, 2014 - 10:48 PM.
  • Alc, Utah Smitty and boyscout862 have said thanks
#3 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 16, 2014 - 10:53 PM
If I thought I could get it running (and didn't have a long list of projects already waiting), I'd be tempted to buy it from him--the city is really on his case to clean up his yard.  After June 22nd he starts getting a $50 a day fine... Anyway, the dozer would be real handy for clearing mom's driveway, etc. but parts would be all but nonexistent.
Smitty
#4 boyscout862 OFFLINE
  • 13,446 Thanks
  • 9,392 posts
Posted June 17, 2014 - 06:09 AM
The new tractor looks good and I hope that you enjoyed playing with it. The small dozer is very cool. I would bet that most of the parts for it are standard off the shelf parts. I have a large AC HD6G and the parts I need most for it are 50 pound cans of welding rod. Probably the same with that one. Good Luck, Rick
  • Utah Smitty said thank you
#5 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted June 17, 2014 - 06:29 AM
Glad you got to put the tractor to work. Takes a bit to get used to FEL's. Thanks for the pics, wish I were closer!
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 17, 2014 - 06:32 AM
It's nice to see you putting that new tractor to work. Maybe you can give us an update when you get a chance to give the BH a workout.
#7 MH81 OFFLINE
Posted June 17, 2014 - 01:20 PM
Smitty
Tell him I agree that the city should mind it's own damn business.
Good luck to all involved
Now, for the positive... nice days work on a nice machine. Hope the grass didnt put any strain on things, but that's a phone call I would make to the dealership, just to remind them not to be cocky.
#8 Cvans ONLINE
  • 7,130 Thanks
  • 6,307 posts
Posted June 17, 2014 - 05:38 PM
You look good on that tractor Smitty. If the radiator was full of coolant and it didn't boil over you should be OK.
On the Kubota G4200 there is a little whistle installed on the overflow tube. If the radiator boils over the steam blows the whistle kind of like the old tea pots. My grandson was operating the Bolens loader last week and he came and got me because he was hearing a whistle on the tractor. Saved my tractor and I made up my mind to install them on the other tractors as I'm not always checking the temp. gauge. You might want to look into something like that.
  • Alc and Utah Smitty have said thanks
#9 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 08:37 AM
We had a couple HD5s and HD6s when I worked at a salvage and rebuild yard.  Tough little machines, but engine, transmission and clutch parts were hard to find... ours were parts machines and there were still people running them that would buy parts from us from time to time.
Smitty
#10 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 08:39 AM
Thanks, Chris... never saw it boil over, so I'm hoping it's okay.  I don't know if mine has a whistle or not. Where do you find the whistles to install in the overflow tube?
Smitty
Smitty
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 08:41 AM
I should be using the backhoe in the next couple weeks to dig a trench for my mother to put in an irrigation system... She collects water from the irrigation ditch, and pumps it to the rainbird sprinklers on her lawn.
Smitty
#12 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 08:43 AM
Yeah, me too!!! You could come over and play on it a bit and we could talk about my Ford LGTs that are languishing in disrepair.  I walked by them the other day and I could hear them whispering among themselves about how neglected they feel.
A guy I know keeps wanting me to sell him my Ford FEL, but I think I'll hang on to it... if nothing else, Mom could use a small loader up at her place.
Smitty
#13 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 18, 2014 - 08:44 AM
I tried a JD2305 BH at the JD dealer one day. It was humbling to say the least. It would take me a while to gain the skill to be productive with it.
#14 boyscout862 OFFLINE
  • 13,446 Thanks
  • 9,392 posts
Posted June 18, 2014 - 08:53 AM
Smitty
Get one of the LGTs with a FEL going soon. I find that there are plenty of times that two machines make work alot faster and safer. Its also nice to have the extra loader when working on the first one. Good Luck, Rick
#15 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 08:09 PM
Yeah, same here.  PLUS, there are two different control layouts--John Deere and Case.  When I did the maintenance on that little Kubota excavator, I unwittingly moved the lever and changed the controls... When the owner went to take it away, he got a real confused look on his face, then told me the best way to mess up a 'hoe operator was to change the operating layout.
I hope to sharpen my skills with the backhoe-- I've already been offered some work if I can get proficient on it.
Smitty
Also tagged with one or more of these keywords: kubota b7100 hst, 4wd, backhoe, front end loader, fel, b/h
