Die For Bending Metal With A 20-Ton Press
die 20-ton press bending metal
48 replies to this topic
#31 KennyP ONLINE
  • 40,847 Thanks
  • 47,077 posts
Posted August 02, 2014 - 01:45 PM
Here's a comparison to the original arms and them attached to the tractor.
  • olcowhand, Cvans, UncleWillie and 1 other said thanks
#32 JBRamsey OFFLINE
JBRamsey
  • 1,567 Thanks
  • 878 posts
Posted October 27, 2016 - 09:07 PM
I have access to a full machine shop at work but if I need to bend thick stock at the house and don't want to make the trip to the shop, I use a cutoff wheel to cut about halfway through my material on what will be the outside of the bend. I bend it and then fill the resulting vee groove with weld. Then a minute or two with a side grinder and a file or a belt sander and it's slick as can be. I've done 1/2" stock this way. I generally don't use anything bigger than 1/2" because it's either not necessary or I just don't want to pick up anything that heavy.
  • Alc, KennyP and Sawdust have said thanks
#33 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 28, 2016 - 04:06 AM
Very good job and upgrade Kenny ,  You guys are making me jealous , i need a press real bad now , i'm telling ya
Shane
Edited by holdenboy1960, October 28, 2016 - 05:42 AM.
#34 lrhredjb OFFLINE
lrhredjb
  • 871 Thanks
  • 650 posts
Posted November 08, 2016 - 06:21 PM
Meet the new and improved version of the die! My thanks to olcowhand and TD&H for opening my eyes a bit. I think this will work much better. The 5/8" block is now 11/16" into the 2X2 with 2-3/8" blocks on either side. All was welded in with the Hobart 140 set on 4 with about 40 inches of wire speed. Take a gander at this:
Last pic is down inside where the push bar of the press will sit. I think this will do much better!
Looks pretty stout, should do the job just fine. Technically that is the punch, the die is the lower part.
  • KennyP and Sawdust have said thanks
#35 olcowhand ONLINE
  • 42,887 Thanks
  • 31,937 posts
Posted February 07, 2018 - 11:12 AM
Kenny, I've yet to build me a bending setup like yours, but I soon will!  Handy as all get out.  I have a manual metal bender that can handle 2" x 1/4" easy enough, but my body can't handle it anymore.
#36 KennyP ONLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 07, 2018 - 11:46 AM
This has worked well for me, Daniel! No issues at all. And I have used a piece of pipe to make radius bends.
  • olcowhand, Alc and Sawdust have said thanks
#37 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted February 12, 2018 - 12:06 AM
I made up a die using a 1" plate with 2 pieces of 1.5 x 1.5 x 3/16 angle with the legs welded to the plate. Then I fired up my vertical wood splitter to serve as the press.
Worked like a charm.
  • KennyP, Sawdust and secondtry have said thanks
#38 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted February 12, 2018 - 06:25 AM
Kenny , I reread this thread again and was wondering , did heating the arms up make it bend any easier ?  I've bent around 1/2" steel by using a torch to heat it cherry red but is a cold bend stronger or no difference ?
#39 KennyP ONLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 12, 2018 - 06:41 AM
It will bend easier heated. I can't say if that would make it stronger or not.
#40 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted February 12, 2018 - 06:45 AM
Kenny , I should have asked if the cooker heated it up to get those arms red ?
#41 KennyP ONLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 12, 2018 - 06:59 AM
Yeah, I used the cooker for heating them. All I have for that kind of heat.
#42 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted February 12, 2018 - 08:15 AM
Kenny what did you use in your cooker...coal? It's going to be awhile before I get anything to heat metal with. Years ago I did heat a piece of leaf spring in a wood stove cherry red to make a Froe but it took a long time.
#43 KennyP ONLINE
  • 40,847 Thanks
  • 47,077 posts
Posted February 12, 2018 - 08:39 AM
It's just a propane turkey fryer burner, Jim. With the plate over the top it got it real red!
  • Alc, TomLGT195 and Sawdust have said thanks
#44 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 12, 2018 - 11:03 PM
Kenny did you receive all 3 cast pieces with your 20 ton press from HF?  I bought my 20 ton HF press over 10 years ago and I only received 2.
  • Sawdust said thank you
#45 secondtry OFFLINE
secondtry
  • 2,151 Thanks
  • 1,528 posts
Posted February 13, 2018 - 02:15 AM
    No camera? Don
