Die For Bending Metal With A 20-Ton Press
die 20-ton press bending metal
48 replies to this topic
#1 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 15, 2014 - 05:17 PM
I just got a HF 20-Ton Press this weekend. Besides using it for it's intended purpose, I would like to bend some iron with it. So I proceeded to come up with a plan. My box of parts for the press came with one extra cast plate, so I took all three and set them with the big Vee up. Next I needed something that would bend the metal better than the round bar stock coming down. I found that 1/4" wall 2X2 square fit over it perfectly. I was going to cut this into a vee and weld a piece of angle to it. But, TD&H (Brian) posted a suggestion to use 1/2" thick material on end here. I remembered I had some 5/8" thick stock, so I proceeded to make the vee on the edge of it. Cut a 3" long piece of the 2X2 square stock and welded that together. I needed a way to hold this die up onto the round stock, so I drilled a 5/16" hole through and welded a nut on for the holding bolt. Tried it out on the 1/2" bar stock I want to bend (5th pic below) and it is a go! A little heat on the bar stock will help as I need to bend them a bit more than they are now.
Here's some pics!
  • olcowhand, Gtractor, MH81 and 18 others have said thanks
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted June 15, 2014 - 05:27 PM
Looks good! Scrap metal is good to have around!!
Geno
#3 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted June 15, 2014 - 05:46 PM
Nice way to get more uses from your press !
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 15, 2014 - 06:38 PM
A press is on my "must have" list.  I can't watch your press threads anymore, Kenny, or that day of buying one will rush closer and closer until it overwhelms me.
Ben W.
  • KennyP, sacsr and boyscout862 have said thanks
#5 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted June 15, 2014 - 06:44 PM
Kenny, you might wanna cut a slot into the square tube so you can slip the bend point up in there for a better stronger joint.  I'd also weld some short pieces of 5/8 onto each side to further strengthen it.  That's a LOT of stress there!  I've seen things fly like bullets from presses, so I had to mention this.
  • Texas Deere and Horse, KennyP, Cvans and 3 others have said thanks
#6 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted June 15, 2014 - 08:33 PM
   Great idea but!!!!!!---------  I would scrap those cast blocks, they are just that.  crap cast blocks that will break sooner than later!  I made a new set for a friend because his broke first use.  Cowhand is rite, when is breaks it will be dramatic and scary.  Go for some solid steel blocks in there you will be safer in the long run.  Otherwise I like it!!!!!!!!  neat idea to use you press as a metal bender.
  • KennyP, boyscout862 and holdenboy1960 have said thanks
#7 Traill95 ONLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted June 15, 2014 - 08:45 PM
Hmmm, I have that same press but only two cast plates. I thin I can work something out about the same as you have done. Thanks for the post and helping me along with more projects now. :thumbs:  :thumbs: :thumbs:
#8 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted June 15, 2014 - 10:00 PM
Kenny, it looks great but I would do as Daniel suggested and set that wedge into the square tube so if the welds let go, it won't become a missile.
#9 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 16, 2014 - 05:44 AM
I'll rework it before I go further. Just happy it will work!
  • boyscout862 and holdenboy1960 have said thanks
#10 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 16, 2014 - 07:18 AM
I have something in mind to make it stronger. I don't have anymore 5/8", but I have some 3/8" I can use. And a slot is the way to go.
I don't have anything right now to replace the cast pieces, but I'll be looking!
#11 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted June 16, 2014 - 08:06 AM
I'm   wanting one now TOO...     Great work kenny..
Iv'e been bending alot of steel lately  to make my 3 pt. and my Briney hitch..
#12 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 18, 2014 - 07:17 PM
Meet the new and improved version of the die! My thanks to olcowhand and TD&H for opening my eyes a bit. I think this will work much better. The 5/8" block is now 11/16" into the 2X2 with 2-3/8" blocks on either side. All was welded in with the Hobart 140 set on 4 with about 40 inches of wire speed. Take a gander at this:
Last pic is down inside where the push bar of the press will sit. I think this will do much better!
  • olcowhand, MH81, GTTinkerer and 6 others have said thanks
#13 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted June 18, 2014 - 08:00 PM
Yes Kenny....much improved!   :thumbs:
  • KennyP, Sawdust and Mark 149 J. have said thanks
#14 UncleWillie OFFLINE
  • 16,252 Thanks
  • 8,970 posts
Posted June 18, 2014 - 10:31 PM
Looks much better now. When I saw that first set of pics I was a bit scared
#15 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 22, 2014 - 09:39 AM
Got busy this morning! First off, getting the turkey frier out and cooking some metal:
Then, in to the press and do some bending:
And the final result:
As soon as I get some weld on ends, I will have another set of heavy duty lower arms for the FF. The gray one next to these is one of my original arms.
  • olcowhand, CRFarnsworth, Sawdust and 2 others have said thanks
