Welding Fees
16 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,117 Thanks
  • 10,188 posts
Posted June 17, 2014 - 12:16 PM
When my job switched from stick, they got a Hobart stick and wire combo machine. The wire didn't work well. It would stick, short inside the tip, snarl up. I think they cut off more wire than they used. I let others fool with it. I continued to use the stick.
Edited by LilysDad, June 17, 2014 - 12:17 PM.
  • propane1 said thank you
#17 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted June 18, 2014 - 06:38 AM
I wish! I don't have much experience with wire, only stick. It would have to be 110v and you don't get much in that.
I have a Lincoln 110V wire feed that I bought 20 years ago.  It does 90% of the welding jobs I need... It'll weld up to 1/4" just fine and will weld thicker if the metal is preheated.  I use flux-cored .035 wire--it leaves some slag, (though not as bad as stick welder), but gives better penetration than solid wire with gas.
FWIW,
Smitty
  • Cvans and LilysDad have said thanks
