Thinking Hard On A Lift Table
45 replies to this topic
#1 olcowhand OFFLINE
  • 43,177 Thanks
  • 32,012 posts
Posted June 14, 2014 - 08:37 PM
I have been thinking a lot about getting a lift table for working on GT's, and servicing my mowers.  It's getting harder to get down, then get back up with my knees & everything else getting older.  It would be a great investment, although expensive.  BUT, if it helps prevent injury....priceless!
  Looking at maybe a Titan XLT 1500lb capacity.  A little over a grand not counting shipping, but there are dealers within 50 miles of me, so I'll give them a call to check their prices.  I'd rather just pick one up, but ebay sellers all have pickup near Indianapolis, which is a good haul from me....380 miles round trip.  I can give more at a dealer & maybe still cost less than driving all that way.
  • Texas Deere and Horse, hamman, KennyP and 4 others have said thanks
#2 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted June 14, 2014 - 08:49 PM
I can agree how much better this would be. I know stability is a major issue but it looks like the platform could be wider to keep your feet away from the base. It might just be the angle of the pic too. I seen a guy took one used for motorcycles & converted it for GT's.
  • tinbender7 said thank you
#3 UncleWillie ONLINE
  • 16,416 Thanks
  • 9,035 posts
Posted June 14, 2014 - 09:22 PM
For now I am just stacking some pallets and putting a piece of plywood over them. Makes a passable work station, but it isn't very adjustable.
  • KennyP and tinbender7 have said thanks
#4 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted June 14, 2014 - 09:30 PM
A lot of the snowmobile shops use the motorcycle lifts with some type of widening kit installed. They definitely work well.
Geno
#5 bhts OFFLINE
bhts
  • 1,483 Thanks
  • 2,170 posts
Posted June 14, 2014 - 09:31 PM
I know what you mean Dan, was glad to get the one I have. It is a shame as there was one like mine at auction just awhile back and I say it went cheap. You will be glad to get one as they do come in handy and saves on the knees. As for the style table you are looking at you may want to check into the people that made mine here is there site http://heftee.com/pr...ts/products.cfm  I have the heftee 2000 dealer service set but they do sell the lift tables. Also even though I did not get it from them they are always calling to make sure it is working good and to see if I need anything for it.
  • olcowhand said thank you
#6 Alc ONLINE
  • 7,357 Thanks
  • 7,638 posts
Posted June 14, 2014 - 10:26 PM
Would it be worth it to spend more $$$  and be able to have a car/light truck lift too. I don't have the height for a full size lift but thought one like this mid rise would be very handy. There are different styles out there , I just grabbed this one to show
http://excel-equipme...CFc9lOgodiVQAXg
#7 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted June 14, 2014 - 11:46 PM
I got the Harbor Freight motorcycle lift, which looks kinda like one in pix here, but added wood platform to make it wider. I have not really used it. Kinda scary with bigger tractor on it, smaller ones OK I guess. I drove last Speedex on there last fall and it has been on there all winter, and piles of stuff on it. It takes up quite a bit of floor space, which I can't really spare. I really think not my best buy. I have some pix of ones that guys have made, which are much smaller, yet wide enough for tractors and open in center, so you could work underneath it some if needed. I can't do that, mine is all closed even when raised. Then, you have the width of table being part of problem of holding you away some on the smaller units, so still a back-ache time. Don't forget the wheelstops too, you need them for sure, I found that out!  Maybe I should just try it more before talking about it, but I know it is un-used at moment. Was only $299.99 with a coupon from a cycle magazine ad. Check them out if you want it cheap. Never that cheap in any other kind of ad that I have seen. Got mine in a local HF store, not shipped.
#8 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted June 15, 2014 - 05:17 AM
    Funny I see this here today!  I was just lamenting to my dad the other day about sore knee's and hurt back.  Looking into building a lift table out of aluminum, something I can just pick up and put against the wall when not in use.  I have access to lots of HI grade aluminum tube and a long reach bottle jack from hf for the lift, maybe a set of upside down C channel to drive the tractors onto and done!  Sound easy rite!  I am going to make something just not sure what or when, I just want it to be light a movable as I don't have much floor space.
     I may even go with a drive on type, I only want to get the tractor up about 2' so If I make a drive on one I could fold it up and put it outside when not in use :D   Still not sure.  Good luck and let us know what you get and how it works out
        Pete
  • Alc and IamSherwood have said thanks
#9 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,166 Thanks
  • 1,332 posts
Posted June 15, 2014 - 05:50 AM
Daniel,
This is similar to the one you are talking about.  A shop 20 miles south of me has two of these.
http://www.ebay.com/...sd=321360569754
  • IamSherwood said thank you
#10 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 15, 2014 - 06:30 AM
I've thought of getting one as well but I'd need it to double as a GT parking spot when it's down at floor level. Working on your knees or bent over is not fun at all as you get older. It also takes longer to work on things if I don't have them at a comfortable height, I drop parts and tools more often when working in awkward positions and it's not good for my mood either when I'm cursing the engineer who make something impossible to service without standing on my head or needing girly hands and a set of needle nose pliers to reach a cotter pin or whatever!. OK! I was starting to rant there but some of these older GTs are difficult to work on IME.
  • Alc, KennyP and HDWildBill have said thanks
#11 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted June 15, 2014 - 06:41 AM
One of those tables would be nice, but I have neither the space nor the funds for one. I'll just use the stands I built (one of these days)!
#12 olcowhand OFFLINE
  • 43,177 Thanks
  • 32,012 posts
Posted June 15, 2014 - 08:40 AM
I'll soon enough have the space, but funds are short here as well, but sometimes ya gotta bite the bullet to make things a bit easier on ya.  I'd build my own, but I just don't have the time.
#13 HDWildBill OFFLINE
  • 8,985 Thanks
Posted June 15, 2014 - 09:06 AM
I couldn't live with out mine.  I put GT's, motorcycles,  mowers, just about everything except zero turns on it.  I have an executive office chair so I can adjust the height and just sit in the chair and work.  I have the HF one and it has worked well for about 2 years now, but eventually I would like to get one that uses air and hydraulic to lift and has extenders for it.  But for under $300 I can't complain and it sure beats getting on floor or bending over.
  • olcowhand, Alc, KennyP and 1 other said thanks
#14 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted June 15, 2014 - 09:07 AM
I'm going to have to 'bite the bullet' and part with a bunch of 'stuff' I have saved. Don't see a use for it and I'll have more space for what I use!
#15 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted June 15, 2014 - 11:10 AM
I have been working on some plane to build one of these, just haven't had time to get it done yet.
  • olcowhand and KennyP have said thanks
