Looking For 10" X 3" Rim/wheel For Jd 140
6 replies to this topic
#1 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted June 14, 2014 - 01:28 PM
I am trying to find a pair of 10" X 3" rims/wheels to fit the front of a JD 140H3 to balance out with the 26 X 12 X 12 ags on the back.  I don't use the tractor for mowing anymore so tearing up the lawn is not an issue.
Thanks in advance.
#2 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 14, 2014 - 04:36 PM
That's a pretty narrow wheel. I'm wondering if a 10" wheelbarrow wheel would be 3" wide. You can get them with 3/4' bearings if that's what your 140 has for axles. The later 300 series tractors are 1"axles but you can get 1" flange bearings to fit those rims as well.
  • GTTinkerer said thank you
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted June 14, 2014 - 04:51 PM
Brian,
They are 1" axles.  I have thought about putting rear axle hubs similar to those on a Sears Suburban, on it without the key after drill and tapping a hole for a grease fitting but figure the would be some major wear on the spindles that way.  I have found new 10" X 3.5" four bolt wheels for around $30 each.
Thanks,
Bill
#4 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted June 14, 2014 - 10:30 PM
You could run a narrow 5.70x8 tire like was standard on the front of the early Bolens large frame tractors. They are 18 inches tall. The Bolens had either 26x12-12 or 27 inch tall 15 inch rear tires. You can get that size as a trailer tire. I have several wheels and trailer tires are here that size.
Edited by rustyoldjunk, June 14, 2014 - 10:31 PM.
#5 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted June 14, 2014 - 10:33 PM
Here is my Bolens 1250 large frame with factory 26x12-12 rear tires and factory 18 inch tall 5.70x8 front tires.
  • GTTinkerer and sacsr have said thanks
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted June 15, 2014 - 01:06 AM
Still looking for a tri rib tire though.  What size is the front spindle on your Bolens?
Thanks.
#7 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted June 15, 2014 - 11:09 AM
My 1250 has 3/4 but they switched to 1 inch later in production.
Sent from my LG-D950 using Tapatalk
