Need Some Advice
4 replies to this topic
#1 Clubmike OFFLINE
Clubmike
  • 23 Thanks
  • 18 posts
Posted June 12, 2014 - 03:02 PM
My cub 129 threw the pto belt off and it looked pretty beat up so I installed a new belt. It was an OEM belt. At first I could not get the pto to engage, then I keep playing with the turnbuckle and got it to engage.
Off I went mowing and other yard work, all of a sudden I smell smoke and and the next thing you know my pto belt which was disengaged at the time burned up.
So I read up on adjusting the turnbuckle and went out and got a new belt but now I cannot get the pto to engage.
I can reach down and turn the pulley which turns the deck, but when I engage the pto with its lever, nothing happens.
If I open the turn buckle too much the pto brake disc drops out, so I went over everything again and I found that the PTO brake disc is supposed to have a wave washer and snap ring. Both of these are missing. Would that cause the PTO not to engage?
Any ideas.
thanks
Edited by Clubmike, June 13, 2014 - 08:26 AM.
#2 cubx4 OFFLINE
cubx4
  • 8 posts
Posted June 17, 2014 - 07:16 PM
Yes sir. Replace and re-adjust tensioner nut.
#3 Clubmike OFFLINE
Clubmike
  • 23 Thanks
  • 18 posts
Posted June 19, 2014 - 09:10 AM
Ok, this is what I found, I ordered the rebuild kit for the PTO clutch and I was surprised at how easy it was to remove the PTO from the engine. I removed the 6 set screws and pulled it off by hand. The guy on the video worked his butt off getting his off. I was not looking forward to removing the PTO from the engine shaft, however it went smooth, real smooth. The fiber cog disk looking thing was in pieces, I guess for this to work it needs to be in one piece.
I rebuilt the PTO and re-installed it and I just got down mowing the backyard. I learned a lot (mostly from you tube) during this experience. The PTO now engages and dis-engages properly.
  • MH81 and HDWildBill have said thanks
#4 HDWildBill OFFLINE
  • 8,978 Thanks
Posted June 19, 2014 - 09:42 AM
Thanks for the feedback.
#5 MH81 OFFLINE
Posted June 19, 2014 - 11:12 AM
Glad it all worked out for you. Good to know that those symptoms are correctable.
