Help!
kohler 14hp new engine spindle 1969 economy
9 replies to this topic
#1 stephenswisher1 OFFLINE
stephenswisher1
  • 5 posts
Posted June 12, 2014 - 10:38 AM
Help! I bought a 1969 Power King Economy. The old 14 hp Kohler was replaced with a NEW 14 hp Kohler engine. The holes that attach the old spindle with the new flywheel are different sizes and do not line up. The Mower Deck will not work without the spindle running from the flywheel. What should I do?
#2 olcowhand ONLINE
  • 41,081 Thanks
  • 31,393 posts
Posted June 12, 2014 - 11:00 AM
First, what model & spec is the replacement engine, and what is the diameter & length of the original flywheel's pto spindle?
  • stephenswisher1 said thank you
#3 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted June 12, 2014 - 12:50 PM
Welcome to GTT. Pics will help us to help you. Good Luck, Rick
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,826 Thanks
  • 2,812 posts
Posted June 12, 2014 - 06:17 PM
Ditto. Tom
#5 Dave Central NY OFFLINE
Dave Central NY
  • 106 Thanks
  • 92 posts
Posted June 13, 2014 - 07:28 AM
What I did was    Drill new holes in the spindle.
#6 stephenswisher1 OFFLINE
stephenswisher1
  • 5 posts
Posted June 13, 2014 - 08:47 AM
Going to my 3rd Machine Shop today to see if I can find someone to drill new holes in the spindle.
#7 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted June 14, 2014 - 09:45 AM
There is a couple diff spindles depending on years and engine sizes. One has 5/16" holes, another has 3/8" holes and the spacing is diff, so not sure you can just bore them out to fit. Think center fits in flywheel the same, would have to check. I have one of those in my stuff, but would have to find out which one. I would send for shipping if it is correct. Want me to look? Best to PM me on the answer.
#8 stephenswisher1 OFFLINE
stephenswisher1
  • 5 posts
Posted July 20, 2014 - 10:46 AM
Thanks everyone. I did get the holes re-drilled and now the drive is working fine, problem is, not I get absolutely zero electric to anything. I can't even get a "click" out of the starter. Is there a "kill" somewhere on this thing?
#9 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted August 09, 2014 - 10:52 AM
Get wire diagram and follow it thru, wire by wire.  Didn't get the year/model you had, but about only safety switch is the pto one. Won't crank if the pto witch is ON. Cleaning battery cables first, charge in battery?  Try crossing the selinoid  from batt term to the small start term to see if it kicks in. OR, can go right across the two big cable terms also to get direct connect, but more sparks that way. Go around and check the wire connections for loose or cut thru somewhere. The key switch has several connections and is a start position on that to check. Cleaning wire ends and connections is good idea. If was working before spindle work, maybe you just bumped a wire or pulled off somewhere?  Give it the once over as noted.  Might be wire diagrams in owner's manuals on this forum. Most are the same, but their are differences for some years, compare to yours.
#10 tonystumped OFFLINE
tonystumped
  • 1 posts
Posted October 10, 2014 - 05:23 PM
I HAVE A ECONOMY POWER KING 14 HP KOHLER. I REPLACED THE COIL AND IGNITION SWITCH .
THE TRACTOR WAS RUNNING FINE AND JUST QUIT . I have juice to the coil but none out.  I need help. thahks
Also tagged with one or more of these keywords: kohler 14hp, new engine, spindle, 1969 economy
