Raider 12 8 Speed Transmission Rebuild
5 replies to this topic
#1 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted June 11, 2014 - 10:59 PM
Hi everyone. Has anyone rebuilt the transmission on their WH? I am considering doing mine but wanted some sage advice if anyone has been through this yet. Mine is locked up and the shifter just flops around. Hopefully parts are still available.
Thanks,
Bill
Edited by catfisherokie, June 11, 2014 - 10:59 PM.
  • A.C.T. said thank you
#2 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted June 12, 2014 - 04:15 AM
It is possible that the shifter came out of the shifting forks and the forks are not lined up properly causing the "locked-up" condition.
There should be a lock nut on a square headed bolt. This holds the shifter in place. Remove the square headed bolt, remove the shifter and re-align the shift forks (to neutral) and insert the shifter back into the forks.
A rebuild may not be necessary!
  • boyscout862 and catfisherokie have said thanks
#3 HANKG ONLINE
HANKG
  • 6,610 Thanks
  • 3,534 posts
Posted June 12, 2014 - 06:50 AM
YES I AGREE HAD IT HAPPEN ALREADY
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 12, 2014 - 07:01 AM
Check the easy stuff first!
#5 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,302 Thanks
  • 10,283 posts
Posted June 12, 2014 - 07:21 AM
I've rebuilt a 4 speed. Everything is available.
  • catfisherokie said thank you
#6 catfisherokie OFFLINE
catfisherokie
  • 14 Thanks
  • 31 posts
Posted June 12, 2014 - 10:49 AM
Man, I sure hope that is the case. I just assumed the worst. My girlfriend was mowing when it happened and said she was just trying to shift from foreward to reverse when it quit. I figured a gear broke off or something since the wheels will not turn. Crossing the fingers. I do need to brag on her a bit here. While mowing earlier, the pto belt gave it up and shredded and she took it in the face and chest like a trooper. Would have scared the wits out of me....lol.
