Allis Charmers Yellow
6 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted June 10, 2014 - 05:24 PM
Hoping you guys will be able to help I have a b212 that I want to paint yellow again. But I need paint codes or the color name ?
#2 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted June 10, 2014 - 05:25 PM
Oh Alonso forgot the paint on the deck is to bad for the body shop to match we tried lol
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted June 10, 2014 - 05:32 PM
Sometimes by removing a bracket or plate, you find fresh paint underneath.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted June 10, 2014 - 05:37 PM
I'll let Josh answer this one.
#5 Dee ONLINE
Dee
  • 67 Thanks
  • 76 posts
Posted June 10, 2014 - 07:23 PM
There are several favorites which have been used on these old tractors.
Here are some links with the discussions:
http://simpletractor...TOPIC_ID=124931
http://www.michaelst...913&whichpage=2
#6 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted June 11, 2014 - 07:40 AM
Old Cat Yellow is a favorite for the late machines...it's so close a match, it's the only real option for aerosol work, and can save quite a bit of dough on bluk paint.
AC New Yellow 925105/925106/925110 is the paint for a B-210 (Late B-100's through end of 200's...early 100's and prior, except for B-1 were AC Old Yellow).  I don't know of a mix spec if you wanted to have some made.
I like Vansickle paints, though some say their alkyd enamels will fade from UV light, but I used it on my Squire and she's a barn queen, and for time it sits out at home and at shows...there has been no affect.  It's inexpensive and easy to use with a gun (I added hardener...no clear coat is necessary or recommended).  They also offer acrylic.  They were great to work with, and I sent in a well preserved piece of my squire for them to match.  They sent multiple samples my way, with different levels of metal flake for me to approve at no charge.
Van Sickle #CML-3025 is the paint of theirs for the late B's...their color "Yellow Riding Mower" is the B-1 AC yellow and is much too light for a B-212.
http://www.vansickle...hp#CustomColors
Here is paint info from Wells Implement.  I'll have to ask them, but they seem to vary on their website on when the thrid shade of yellow came into production.  Either way, it's the one you will use.
http://www.wellsimpl...com/bseries.htm
Omni Basecoat; a prophet version of Monte Carlo Yellow MBC83460
(This is a 2 coat process!)
(The first coat will be the yellow and it will be dull as primer, the second coat will be the clear coat and make it very shiny)
119 White 92.0-----92.0
114 Yellow 576.7--487.7
118 Black 582.0-----5.4
130 Orange 597.5--15.4
150 Basemaker 1195.0--597.5
For my use, I have only used Old Yellow (on my BIg Ten), and Old Cat Yellow (on some implements and late B series touch ups).  I've been happy with the Old Cat aerosols, but am not sure I'd use it for an actual full restoration . I would have to have things 'right' if going through all that effort again.  I used Industrial Touchups paint #94857 for my Big Ten.  Their product #94858 is appropriate for your B-212.  They do a nice job also, and you can order aerosols from them.
http://www.industria...s-chalmers.aspx
Edited by Talntedmrgreen, June 11, 2014 - 07:51 AM.
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 12, 2014 - 09:38 AM
I had my early B112 paint matched of an interior panel at Farrell-Calhoun. This was their match.
Farrell-Calhoun industrial gloss enamel
Neutral base 857
Ax-9y2
C-y
F-8
Kx-3y38
Unfortunately I never got to paint the tractor, but I did brush paint a couple of implements.
This is not quite right for late machines but is closer than Old Cat Yellow.
Edited by skunkhome, June 12, 2014 - 10:13 AM.
