Cordless Tool Charging Station?
cordless tools
11 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,100 Thanks
  • 2,621 posts
Posted June 10, 2014 - 06:20 AM
I'm getting ready to buy a "Core" 20V cordless trimmer, already have 12V & 18V shop tools.  I'm thinking of putting all the chargers in one place for convenience.  I know your not supposed to leave the batteries plugged into the chargers for long periods of time, but what about if the charger isn't turned on?  I'm thinking of putting all the chargers on one (switched) power strip so I can just switch it off & on as needed.
Anybody know of any problems with this idea?  ~~  Lowell
OOPS!  Misspell on title (should be Tool, not toll)!!!!  :wallbanging:  :wallbanging:  :wallbanging:
Edited by grnspot110, June 10, 2014 - 06:23 AM.
#2 Sparky OFFLINE
Sparky
  • 1,296 Thanks
  • 1,892 posts
Posted June 10, 2014 - 06:25 AM
Most modern chargers have a battery sense circuit to sample voltage before the charger will turn on . This circuit would eat a minute amount of power which could add up over time .
  • grnspot110 said thank you
#3 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted June 10, 2014 - 07:50 AM
Being in construction & having a lot of electronics I personally don't trust any battery or charger. Since our devices & components are made & assembled from all over the world one faulty component could be disastrous. The idea of a charging station switched on one circuit sounds good but don't leave batteries connected regardless.
#4 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 10, 2014 - 08:03 AM
I fixed the title for you. It depends on how the chargers are designed. If there is some sort of parasitic load on the battery when the power is off it will gradually run down the battery when the charger is unplugged. This has been my experience with at least 1 type of charger. I would look at the owners manuals to see if there are any guidelines on leaving the batteries in the charger.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 10, 2014 - 09:03 AM
I'm the worlds worse when it comes to leaving batteries in the charger.  I usually have 2 or 3 batteries so when one goes dead I just pop in another one put the dead one in the charger and promptly forget about it until a day or so later I see it and go :wallbanging: :wallbanging: :wallbanging:
I have done what you are talking about Lowell.  I have 2 chargers plus a small fan on a strip.  The fan is tor remind me to turn off the strip before closing the shop up.  I don't leave the battery in the charger unless I have another seniors moment and forget but I do figure that at least with the power turn off it is better for the battery then just leaving it.
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,360 Thanks
  • 2,837 posts
Posted June 10, 2014 - 09:18 AM
When I get the new garge fully wired I will have one spot where I will have my chargers for all of the "Toys" uh...."Tools yah Tools".. I want to put it on a seperate circut dedicated for just that. I will have it on a GFCI and it should be okay.  I am bad at leaving batteries on the charger. Just can't seem to remember to take them out of the charger.............just had to run out and take one out that has been in one for a couple of days. Thanks for reminding me.  Seriously I have 4 different drills, and screwdrivers that are rechargable. I plan on having a 40v trimmer by Worx next year. I just want them to to be in one place where I can get them easily. I don't like using the strips for plugging chargers into. I had talked to an electrician about using a heavy duty timer for shutting the chargers off and he said don't do it because the draw might overheat and cause a fire.  thanks for the post.  Good Luck.        Roger.
  • HDWildBill said thank you
#7 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 10, 2014 - 10:38 AM
Some of my cordless tools have smart chargers that you can leave plugged in & batteries connected with no issue.  One way to not forget on those "dumb chargers" is to put an outlet timer on them so they cannot overcharge.  Set to so many hours & walk away.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted June 10, 2014 - 05:24 PM
I always unplug my chargers when the batteries are charged, and I leave the garage. I do not leave anything plugged in when unoccupied. (31 years on the fire department and seen a lot of garage fires).
I do how-ever leave the batteries in the charger. I have noticed lately the batteries being "dead" or very weak when I remove them from the charger.....Wonder if the drained batteries is from being in the un-plugged charger, or maybe they are just shot!
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted June 10, 2014 - 06:49 PM
I have a foot long wood shelf on the wall right above the air compressor, with a strip outlet fastened to the underside of the shelf, facing out so the red light on the switch is visible.
#10 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted June 10, 2014 - 07:40 PM
I have my workbench light plugged into the strip with my chargers so they get shut off every time I leave the garage.
Geno
#11 grnspot110 ONLINE
grnspot110
  • 4,100 Thanks
  • 2,621 posts
Posted June 15, 2014 - 11:47 AM
Where would I find a timer that doesn't come back on 24 hours later?
I would want one that when turned on, stays on 3-4 hours, then shuts off until I restart it!  ~~  Lowell
#12 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 15, 2014 - 11:54 AM
Not as simple to wire but HERE is a 4 hour timer that shuts off.
