Simplicity Sunstar Motor Dies
5 replies to this topic
#1 cf5810 OFFLINE
cf5810
  • 1 posts
Posted June 09, 2014 - 04:41 PM
I have a sunstar that the motor dies or when it leaves neutral. When its in neutral everything runs as it should, even the PTO. Seeing if there are any suggestions. The tractor # is1691381 if that helps. Thanks
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 09, 2014 - 05:12 PM
Sounds like an interlock switch of some kind that isn't functioning properly.
  • boyscout862 and superaben have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted June 09, 2014 - 06:52 PM
I bet the seat switch or parking brake switch is out of kilter.  On a Sunstar, there is no brake pedal switch since it has individual wheel brakes, but it does have a parking brake switch.
I suspect the problem is the parking brake switch.  It usually doesn't start when the seat switch is in a grumpy mood.  I think you have to be in the seat for the Sunstar to crank.  Some Simplicity tractors don't require that.
Ben W.
#4 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted June 10, 2014 - 04:34 AM
Welcome to GTT. Good Luck, Rick
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted June 10, 2014 - 06:05 AM
:welcometogttalk:
#6 mtoney OFFLINE
mtoney
  • 824 Thanks
  • 685 posts
Posted June 10, 2014 - 07:16 PM
Yes, you have to be in the seat for it to crank, I am also thinking its the parking brake switch thats acting up.  Mike
