99 Ford Ranger Engine Questions
46 replies to this topic
#46 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted October 29, 2014 - 10:57 PM
   Cleaned it up really good, then used liberal amounts of RTV sealant to seal the gasket in place.
sounds like someone is looking for more trouble there, especially if the gasket was a rubber type.
  The upper "A" arm ball links are bad and need replaced,
Ball JOINTS.... many of which CAN be replaced without changing the whole control arm.... despite what ford says.  look to MOOG suspension parts.
Regarding the oil gasket:
1) it is the rubber type
2) this marks the SECOND time that thing has squished out from between the block and oil pan.
 It is hopefully secured both top and bottom now.  I wonder about pressure buildup, and will be replacing the PCV valve, but there is also a breather port at the oil fill cap on the valve covers, so it seems unlikely that pressure buildup would cause the gasket to blow out.
#47 Alc ONLINE
  • 6,902 Thanks
  • 7,468 posts
Posted October 30, 2014 - 05:31 AM
We had a Ranger with a oil pan gasket that started pushing out right under the front bearing/seal , I got lucky by just loosing the bolts and pushing it back in place , I wish I could remember if I tried to hold it in place with any sealers or glues :wallbanging:   ,
