Welding Questions...
82 replies to this topic
#61 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted June 16, 2014 - 08:33 PM
Nice looking welds. :thumbs:
...try doing a butt joint and try the break the weld...
I agree. This will show you alot. Try playing with the machine, Increase/Decrease amperage, speed, wire feed. This will help you learn the machine. Anything over 1/4", or if you can get to it, weld both sides.
No professional here, everytime I have a nice lookiing weld, there is little penetration. So I always just 'burn it in' and let the grinder smooth it out.(I need more practice) Only have had a few welds break(less than 5 in 20+ years), most of the time(99.9%) it breaks at a factory weld, so I don't feel bad about my welds. Good luck and keep practicing.
  • WNYTractorTinkerer and iZach98 have said thanks
#62 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 16, 2014 - 08:38 PM
Thanks all! Im glad i got it right, here are a few more pics ImageUploadedByTapatalk1402969068.846117.jpg
Here is part of a small project im starting, im gonna weld up a stick figure. ImageUploadedByTapatalk1402969115.896091.jpg
#63 lyall ONLINE
lyall
  • 2,169 Thanks
  • 1,573 posts
Posted June 16, 2014 - 10:23 PM
iZach98
welding 1/4" or thicker material you can bevel your steel  to help get at good weld
get a couple good books on welding - they will help explain a lot or how to weld different thickness of steel
once you have learn how to get a good flat weld try welding pipe
it is a little harder - more grinding to get to piece to fit together
#64 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted June 17, 2014 - 03:04 AM
Your coming along fine, as you get going you have a good looking weld. You need to dwell a bit mor at the start so you get heat into the parts. Once you get your puddle started , then continue. Same thing at the end, you stop for a second then back up a tiny bit. This helps to stop craters and cracking from cooling.
#65 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 17, 2014 - 03:57 PM
So i welded up this little stick figure, just to try out welding pieces together. What do you think? ImageUploadedByTapatalk1403038627.611764.jpg
I have to wire wheel it or something to make it look nicer lol.
Edited by iZach98, June 17, 2014 - 03:57 PM.
#66 TomLGT195 ONLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted June 17, 2014 - 06:11 PM
I believe all the white stuff is from the flux but looks good. Try a wire brush to clean up something that delicate.. Try welding a but joint on flat pieces to check for penetration. Making sure you get enough heat to discolor the back.
#67 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 18, 2014 - 07:52 PM
Does anybody know if i can put a metal cutting blade on this dewalt chop saw? ImageUploadedByTapatalk1403139066.279622.jpg ImageUploadedByTapatalk1403139086.329374.jpg
Im going to need to cut 1" square tube for a bike rack my mom wants me to build. Just wondering if i can use the chop saw to get a cut that more square than an angle grinder.
#68 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 19, 2014 - 08:02 PM
So my aunt maria's birthday is this weekend. And we are going over there to visit and celebrate. So i figured, i'll weld something up. I was browsing the internet for ideas. And i found a flower for a garden made from washers, flat steel, and a steel rod. So here is a pic of what i was aiming for ImageUploadedByTapatalk1403226014.896963.jpg
I kinda over built it, as i do with anything i build. This is the back of it...ImageUploadedByTapatalk1403226090.647915.jpg
Im just going to clear coat it, to prevent rust. I like the blue heat tint from the welds. by the way, it is completely welded from the back, no welds on the front of it. What do you think? Close to what i was looking at? Better? Worse? Give me your opinions. 😃
Edited by iZach98, June 19, 2014 - 08:04 PM.
  • trowel, bgkid2966, TomLGT195 and 1 other said thanks
#69 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 19, 2014 - 08:09 PM
It came out very looking good :dancingbanana: , in a flower garden it would stand out but at the same time blend in with the blue heat tint like a silver petal blue core flower.
It is welded up so good i'll bet you could use it as a hammer :thumbs:
Edited by trowel, June 19, 2014 - 08:11 PM.
  • iZach98 said thank you
#70 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted June 19, 2014 - 08:10 PM
Looks good! You are getting a lot of good advice. Keep practicing. :thumbs:  :thumbs:
Geno
#71 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 19, 2014 - 08:13 PM
I think it flat out suxs so bad you should never weld ever again !!!
Kidding, kidding, i know, im a jerk, anyways, it came out very looking good :dancingbanana: , in a flower garden it would stand out but at the same time blend in with the blue heat tint like a silver petal blue core flower.
Lol thanks, i know the beads aren't the best, but it will hold. I gotta practice on my beads more. But for just starting to weld a few days ago i think it looks pretty good.
#72 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Does anybody know if i can put a metal cutting blade on this dewalt chop saw? attachicon.gifImageUploadedByTapatalk1403139066.279622.jpgattachicon.gifImageUploadedByTapatalk1403139086.329374.jpg
Yes, i think stores like Home Depot sells it.
#73 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 19, 2014 - 08:14 PM
Yeah, i spoke to my dad. He said it will take a metal cutting blade.
  • trowel said thank you
#74 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 19, 2014 - 08:15 PM
Naw, it is not the looks of the bead that matters but the quality, try swirling the pool instead of zig zag.
On a V or step between the metals (god my discriptions suxs) use a stepped C pattern.
Edited by trowel, June 19, 2014 - 08:17 PM.
#75 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted June 19, 2014 - 08:17 PM
I was doing swirls, maybe not enough of the swirl motion. Ive got the day off from school tomorrow. So ive got some more time to practice.
Im going to make another one for my chemistry teacher who is retiring after 30 years. So i have to get some more washers tomorrow.
