White Outdoor Products 1855 Gt
8 replies to this topic
#1 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted June 08, 2014 - 10:34 PM
Model 144-998-190.........I'm guessing MTD Model 998.  Looking for the proper starter for it. As near as I can tell, the number on the bottom plate is 9304137, with the "7" punched over a hole in the base plate and not easy to see if it is a 7. It's my boys and he "burned out" something at the other end of the starter and wants to piece it in rather than refurb(read remove and refurb....$$) the whole starter. His GT, his call.  Any ideas as to what this starter number is or should be?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 09, 2014 - 04:53 AM
What engine do you have on the tractor?
Ben W.
  • trackcar said thank you
#3 VTXrider ONLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted June 09, 2014 - 07:44 AM
This may help narrow it down but you will need to know the engine model number - stamped on the sheet metal. Usually on top or bottom of the fan flywheel housing.
http://www.partstree... GT-1855 (1994)
These small starters are common to many B&S engines. If the magnets are broken from over heating, it may not be worth trying to repair it. I get many of my engine parts from http://www.jackssmallengines.com/
#4 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted June 09, 2014 - 09:18 PM
Ben W.
Oh yeah. I knew I forgot something. B&S Vanguard 18 hp twin.  Engine model no. 350447 , type 0119-01
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 09, 2014 - 10:07 PM
Is the ring gear on the flywheel aluminum or steel?  I guess they have different pinion gears accordingly?
I can get you a starter for a steel ring gear engine for a really good price.  $89 brand new.
Ben W.
#6 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted June 09, 2014 - 10:14 PM
Ben W.
The GT belongs to my one son, so it may be a while till I check. Also, I'll have to see what he has in mind. I do appreciate all your help.
  • superaben said thank you
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 09, 2014 - 10:43 PM
No problem.  You might have to PM me to get my attention if you decide to need one.  I can get the aluminum version also, just not as good a price.
Ben W.
#8 VTXrider ONLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted June 10, 2014 - 06:44 AM
Parts are available for rebuild.
http://www.jackssmal...stratton/124035
#9 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted June 14, 2014 - 10:04 AM
Thank you, superaben and VTXrider for your help. He called me today and told me he picked one up at Messicks , a tractor biz here in the county and was ready to mow. I did send him info that you guys had and if it was a suggestion it worked!!  Thanks again.
