Troy Bilt Super Tomahawk Hopper Extension
10 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 08, 2014 - 06:49 PM
I think this was MTD, NOS plow blade.
  • olcowhand, Alc, CRFarnsworth and 3 others have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 08, 2014 - 07:04 PM
Finished and painted, good enough,..
#3 lyall ONLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted June 08, 2014 - 08:53 PM
it should work okay
just do not feed it to fast
now all you have to do is figure a way to clean out  after things are shredded
I have a old WW Grinder model 2 with a 5 hp and Renegade 250 with a 8 hp
always have to shovel it out
wish I had something like this
it was made by WW Grinder
Edited by lyall, June 08, 2014 - 08:54 PM.
  • Alc and trowel have said thanks
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 09, 2014 - 02:58 PM
Yeah, me too, a mini one or at least a small screw auger type from a combine, ventures a good thought,.......
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 15, 2014 - 08:59 AM
Ran into a problem with the drive belt, im hoping you guys can help me with.
The seller put on a new drive belt when i bought it, 5/8 x 29 kevlar coated, it eat it right up within 30 min, wore through the sides to the inner core, bought another yesterday, eat that one in about the same time, side wear again, i am starting to wonder if this takes the A belt ? .
The chipper/shredder has a idler pulley clutch that i slowly engage until up to speed, during that engagement is when most of the wear occurs spitting the kevlar coating. Under a load (chipping/shredding) i noted it slipping a bit, the alignment of the PTO pulley to the driven pulley is straight.
It seems i am left with one of two choices, find a heavy duty replacement belt that will tolerate heavy side wears or replace the idler pulley clutch with a mechanical clutch.
Does anyone know of a distributor that provides a manual engagement mechanical disk or cone clutch for 1 '' bore - 4 1/2 diameter pulley for B belt ?
Electromagnetic clutch would require battery and charging system so that's out.
#6 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted June 15, 2014 - 09:09 AM
What I see calls for a W5L290 like you had on it.  Mine has a 4L belt on it at the moment.
  • trowel said thank you
#7 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted June 15, 2014 - 09:17 AM
The belt used on these is a special size , I do stock the belts for these chippers
http://www.ebay.com/...=item258fcd7970
Just send me a PM if interested , price is less than the one on ebay with the "Gtt Discount" :D
#8 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted June 15, 2014 - 09:26 AM
I suppose that special size is designated by the "W" ahead of the 5L290.
#9 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted June 15, 2014 - 09:27 AM
Yep, when I put the full number in, ALL references specify it as a Troy-Bilt part.
#10 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted June 15, 2014 - 09:30 AM
Yes, Bolens/Troybilt always seemed to use odd size belts!
#11 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 15, 2014 - 11:23 AM
Yeah, i was able to find out the size being of 5/8 '' x 29 '' but i gess my mistake would be not getting the OEM.
Bolens1000 im sending you a PM now.
