Hydro Filter ?
10 replies to this topic
#1 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 07, 2014 - 11:59 PM
my  hydrostatic simplicity has a filter in the back # 1671234  and was talking to a guy at napa he said couldn't cross over so we called all the places we could think of for the right one but with no luck so he said the napa gold filter 7035 would work just fine. My ? is will it be ok or will it screw something up . the filter has the same threads and same rubber ring in the same place just wonder if its gonna cause problem the filter said 28 micron and the old one said 25 micron any help would be great ,hate to mess up a good tractor :biting_nails:
#2 skifoof OFFLINE
skifoof
  • 54 Thanks
  • 85 posts
Posted June 11, 2014 - 09:31 PM
I use john deere hydro filters on my 900 series,i cant remember at the moment if it was from a 430 or 317 and there way cheaper than simplicity,and it fits my mtd 990 as well
#3 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 12, 2014 - 04:45 PM
can't seem to find any around here other than the 7035 from napa and i don't think its a hydro filter just something that fits it, just wanted to know if it would hurt anything if i was to leave it on there or if would bust,clog or screw something up any help would be greaat hate to use it on there if its gonna mess things up and i can't find any thing else around here that fits
#4 KennyP OFFLINE
  • 32,709 Thanks
  • 42,317 posts
Posted June 12, 2014 - 06:07 PM
That is a good filter! Here's the specs on it:
#5 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 12, 2014 - 06:17 PM
so this will work ok on the rear end as a  replacement for 1671234 simplicity hydro filter? also thanks for the help :worship:
#6 KennyP OFFLINE
  • 32,709 Thanks
  • 42,317 posts
Posted June 12, 2014 - 06:25 PM
It's definitely a hydro filter! 32 Micron is pretty small. Not sure if the bypass pressure is right for you as I don't know your equipment!
#7 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 12, 2014 - 06:46 PM
mine said 25 micron and the napa guy said that 7035 Gold was a 28 micron but he said that it was for oil only. So thank you for the info its good to have someone that really knows . Thank you so much for the info . :worship:
#8 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 12, 2014 - 06:48 PM
my equipment is a hydro simplicity 7100 series  is it ok for that?
#9 KennyP OFFLINE
  • 32,709 Thanks
  • 42,317 posts
Posted June 12, 2014 - 06:52 PM
I haven't a clue what the specs are for that tractor. Hope someone in the know comes along. I just looked up the info on NAPA's site!
#10 Bill2 OFFLINE
Bill2
  • 35 Thanks
  • 70 posts
Posted June 12, 2014 - 06:56 PM
Ok thanks for the info and may be that someone on here has had the same problem   thanks again :wave:
#11 bobkat2 OFFLINE
bobkat2
  • 1 posts
Posted July 04, 2014 - 01:35 PM
If you have the rear tiller attachment, make sure you use the short filter or else the power belt to the tiller will rub through the filter. I have used oil filters in the past and have not had any issues. However that is just my experience with using oil type filters when I am unable to find the 1671234.
