Jd 400 Mitsubishi L3E Diesel Repower
348 replies to this topic
#121 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 18, 2014 - 06:07 AM
Thanks guys, I will be looking into this a little more after I make some changes to the system. I question if the system had a topped off radiator, and also if the t stat is still good. I would assume it would be good measure to replace it to get it taken care of and out of the way.
  • Cvans said thank you
#122 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 18, 2014 - 10:38 AM
 Yes, too hot, but could be the gauge too.
#123 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 18, 2014 - 08:03 PM
Well, success! Ironically enough, hype elec fan that I cut out to use the mechanical fan fit back into the shroud, I had to move it in about 1/2" but it spins freely and clears both the pulley and the radiator face.
So now it's hooked up to the switch. It runs when I warm up the plugs. It pulls a lot out.
Should I hook up a time delay relay or add a t stat relay to turn on at a specific temp?
#124 Cvans ONLINE
  • 7,279 Thanks
  • 6,371 posts
Posted September 18, 2014 - 08:29 PM
Fan relay's are a good thing. I would use a thermostat to control it. I'm using an adjustable one with a remote bulb that is attached to the upper part of the core inside the shroud. I picked these up at O-Riley's auto parts.
If I remember correctly the contacts on these are rated to handle the fan.
http://shop.advancea...36-P#fragment-2
Edited by Cvans, September 18, 2014 - 08:30 PM.
  • Pager450n said thank you
#125 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 18, 2014 - 09:41 PM
Very nice, I might just do that. I just have to get my kitchen pass back. I snuck out of the house to finish this elec mod and she got a little mad I was outside and not helping.
#126 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 18, 2014 - 10:17 PM
Okay, heres a quick video as promised.  Not much of a walk around, but you can get an idea of it.
Will post a walk around soon, but it wont be until next weekend
Enjoy
https://www.youtube....h?v=l6xt2g2N5ig
  • tweidman and Cvans have said thanks
#127 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 18, 2014 - 10:19 PM
Enjoy
I forgot this loaded up.  Hard to hear what the heck I was saying but that doesnt matter.  The deere sounds just fine and looks great!
https://www.youtube....h?v=X8LmtyO4Z8Q
#128 Cvans ONLINE
  • 7,279 Thanks
  • 6,371 posts
Posted September 18, 2014 - 11:53 PM
Nice machine and your hood really turned out nice. :thumbs:
Thanks for the videos.
#129 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 19, 2014 - 12:21 AM
Your welcome! This forum knows how to help out those in need. For me, I had the need spruce the 400 up for such a long time, and then BAM, I'm rolling coal!
Anyone reading this and wanting to repower their 400, I hope this will help out.
Bring on the snow, I mean dirt!
#130 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 19, 2014 - 12:37 AM
I forgot to mention that during my video, I had the engine running for ten minutes before. I watched the temp, and it didn't go over 190, well over 185. Worked out great!
#131 spartacus OFFLINE
spartacus
  • 3 Thanks
  • 2 posts
Posted September 26, 2014 - 09:26 AM
Looking great! You might want to beef up the hydro cooler with a 7x13 inch cooler as with your added power you will work it harder. Also I update mine with Redline Syntehtic ATF type f fluid. Its what the Sunstrand calls for but synthetic.  Awesome, custs down the noise!  Looking forward to finished product!
Jim
#132 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 26, 2014 - 10:25 AM
Yes, a cooler is a must if using hard, especially plowing.  Great work!
#133 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 26, 2014 - 10:20 PM
I just checked and I did pick up a hydro cooler last week. It's approx 7x 10x 3/4". I'm thinking I will put it in front of the radiator, checked it out tonight. The fan draws enough air, plus I might run it through the existing one as well.
Thanks for the info, and advice!
#134 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 26, 2014 - 10:21 PM
Jim
I've been needing to change the fluid after this repower. I will switch to the redline and watch the temps.
#135 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 26, 2014 - 10:26 PM
So mechanically, all I have to do is hook up the throttle and also rig up the manual to lever.
Cosmetically, I need to attach the rear led lights, front head light( led bar, home made) and front grill with diesel label.
Coming darn close , oh and a seat:)
