Jd 400 Mitsubishi L3E Diesel Repower
348 replies to this topic
#226 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted October 22, 2014 - 07:12 AM
Had that happen before myself, so now if I have to make a driveshaft, I like to use an end mill to cut the keyway.  Drop the cutter down, mill to length, then raise the cutter.  I have a slot with end walls that way, and the key can't come out.
  • limebuzz and Cvans have said thanks
#227 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted October 30, 2014 - 09:36 PM
Another fix is to have a set screw over the keyway slot and snug it in, or even to peen over the slot ever so slightly on the open side...
Smitty
#228 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 31, 2014 - 05:45 PM
I can SEE!
so, first off I ordered those LED drivers, along with some spair led pucks.  I love finding packages by the door.
Pack of ten total, 8.75
Pack of ten drivers, 5.75
Greased hand showing the drivers, not bad.  12-24vDC input producing 11.8 vdc
I spaced the nine leds at approx 1.5" appart, leaving approx 1.5" on the ends to accomidate the sloping lens.
Let it begin
Thermal conductive paste, almost 9 bucks for 2.7 grams
#229 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 31, 2014 - 05:52 PM
Wiring went with 3 sets of 3.  They all ran in parallel, gounding with the radiator t stat fan.
backside
all components will get a good coating of silicone after they burn in and I make sure none are bad.
TA DA!
I had to drive it into the garage just to try it out.
  • tweidman, olcowhand, Alc and 1 other said thanks
#230 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
What do you think?
#231 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted October 31, 2014 - 05:59 PM
Me thinks you can see now!  Seriously, hard to tell from here, but it appears much brighter than std GT sealed beams.
#232 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted October 31, 2014 - 06:03 PM
Those aren't working good! I'll take them off your hands and you can make some new ones!
#233 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted October 31, 2014 - 06:40 PM
Looks like you really had a bright idea there.  :smilewink:
Just curious but what do you think you have invested in that light? Looks good!
#234 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 31, 2014 - 07:27 PM
Cvan, here's a rough cost per item
10 3w led pucks- 9 ish?
10 led drivers, 3 used. 8
Thermo paste. 9
Wire and solder 5 ish
So, maybe a total of 45 bucks. The OEM lens was the most expensive at 52
  • Alc and Cvans have said thanks
#235 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted November 03, 2014 - 08:44 AM
When you are all sure everything is good DO NOT USE SILICONE SEALER!! The vinegar smelling stuff will corrode all the copper connections . Use a urathane based sealer / epoxy based sealer material.
You can't believe how many Fisher, Diamond, Myers and Boss plow units I have had to repair because they "siliconed" the wire connections....
  • Alc, diesel nut and Pager450n have said thanks
#236 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted November 03, 2014 - 09:07 PM
There is an electronics grade silicone available. Try Radio Shack or order on line.
Edited by Cvans, November 03, 2014 - 09:08 PM.
#237 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted November 03, 2014 - 10:32 PM
I second that.
Those vinegar-smelling sealers have ascetic acid in them... we had a similar problem happen with a corrosion problems with TOW Missiles in their storage containers... took a while to figure it out, but they finally realized that ascetic acid from some of the sealants used in the missile were the cause of the corrosion.
Smitty
#238 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted November 07, 2014 - 08:05 PM
So, i was also thinking about maybe sealing with handyman in a can or use Plastic dip?  Not sure, but im kinda sad right now.  I have very little left on this project then im done :(
  • Cvans said thank you
#239 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted November 07, 2014 - 09:13 PM
That's a feeling I have also experienced. Kind of like getting to the end of a good book. Then comes the big "Now what do I do?" .
#240 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted November 21, 2014 - 08:17 PM
chipping away at the little things.
LED tail lights
changed fluids in the hydro
changed filter in hydro and engine
15w-40
I did play with the sweeper attachment today.  I installed the new brushes and its not bad.  I was hopeing that it would throw items a little less....in the up direction.  But hey, it does the job.
I also need to change out the old glow plugs.  Still has a hard time starting, so Im going to start troublshooting the compression, possible air in the fuel lines, hopefully no issue with the pump.
  • olcowhand, Alc, Cvans and 1 other said thanks
