Jd 400 Mitsubishi L3E Diesel Repower
348 replies to this topic
#136 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted September 27, 2014 - 07:25 AM
Plowing gets the hydro's hot....very hot!  On those I've added coolers too, they have never gotten hot.  Before, you could smell the heat, and even made some slightly leak at gaskets from the oil being thinned so badly.
#137 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted September 27, 2014 - 07:38 AM
I just bought an oil thermostat off ebay for my Massey w/FEL.  This tractor gets used in the winter, so now it will bypass the cooler until the oil temp reaches 170F.  The hydro is really grumpy at cold temps, so this should help.  This won't help the separate loader hydraulic system, but it warms fairly fast anyway.  It was NOS and only one listed like it.  Less than $22 to my door, when new is over $70.
  • Cvans and twostep have said thanks
#138 KennyP ONLINE
  • 40,170 Thanks
  • 46,778 posts
Posted September 27, 2014 - 07:51 AM
That's a neat valve! Should help out!
#139 Cvans ONLINE
  • 7,093 Thanks
  • 6,298 posts
Posted September 27, 2014 - 11:38 AM
If it's like mine it's noisy also. Sure nice when it warms up. Started putting a small Nebco heater behind it for about twenty minutes before starting. Starts and runs like summer time.
#140 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted September 30, 2014 - 09:54 PM
Well I got the relay for the radiator fan installed. Started right up the engine and let it run till I got it around 180, adjusted the relay and the fan kicked right on!
BUT after I turned it off, I went to start it up and it just chugs, it doesn't start????
I have checked the fuel, glow plugs and intake. All are good.? Not sure what to make of this?
What should my glow plugs ohm out to?
What psi should I be sending to my injector pump?
And should I pop test my injectors? If so, about what psi should they pop?
Edited by Pager450n, September 30, 2014 - 09:55 PM.
#141 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted October 01, 2014 - 07:11 AM
Do you have manual shutoff or a solenoid?  If manual, not sure what the problem could be, but if electric solenoid, check that it is working.
#142 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 01, 2014 - 08:28 AM
I have a elec coil, with manual push.  I checked the coil and its not open, so its still good.  Maybe the rod is partially stuck?
I can crank it and it fires and continues to fire as the starter is engaged, then quits when the starter stops
#143 Cvans ONLINE
  • 7,093 Thanks
  • 6,298 posts
Posted October 01, 2014 - 10:00 AM
Sure sounds like a fuel delivery problem.
#144 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 01, 2014 - 12:21 PM
So can the fuel rail stick?
#145 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted October 01, 2014 - 03:13 PM
All I know is that some large diesels can have the fuel rail stick closed.
#146 Cvans ONLINE
  • 7,093 Thanks
  • 6,298 posts
Posted October 01, 2014 - 08:45 PM
Diesels can have runaways so I suppose they can stick closed. No experience with that though.
#147 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 07, 2014 - 02:22 PM
Finally got the throttle hooked up. Although the new throttle cable did not have a plastic sheeth (sp) for water resistant. I took some heat shrink tubing and ran it all the way and worked out great. Will post picks after my computer decides to run.
#148 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted October 07, 2014 - 02:25 PM
I have seen some videos of guys frantically looking for a rag to throw into the intake.
I did get it running. I'm not sure what happened ?
I now have another gremlin to figure out. Each night I check the voltage and the battery is all ways dead. I have to charge it up and start again. I checked some acc leads to the fuse box and with the key off, they have a 1.5 volt reading on them?... I might have to switch the connection on the switch.
#149 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted October 07, 2014 - 03:50 PM
Could be the diodes gone bad in the alternator.  When you throw juice to the alternator, the shaft & pulley become magnetized.  Take a small nail & touch to the alternator pulley with key on & you'll feel the pull.  Then turn key off & the nail shouldn't be drawn to it.  If it is, the diodes have gone bad.
  • Alc, KennyP, Cvans and 3 others have said thanks
#150 Cvans ONLINE
  • 7,093 Thanks
  • 6,298 posts
Posted October 07, 2014 - 06:57 PM
Now there's one I have never heard of before. Just hope I can remember it
