Kohler K Oil
7 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted June 07, 2014 - 11:16 AM
The "K" is supposed to run 30W in warm weather. If I switch to synthetic, I believe I can only find multi weight. What then? Also, I've been running truck oil(Rotella) to deal with the zinc issue. How does synth. do for the valves?
What oil do you folks use,?it seems single weight is going away.
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 07, 2014 - 11:29 AM
I don't run anything synthetic in my older engines.
  • LilysDad and superaben have said thanks
#3 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted June 07, 2014 - 12:33 PM
I read some where that you can use 10w-30 oil in warm weather, but just check it more often.  I use 30w in my engines, but all so use 10w-30 too.  Noel
  • LilysDad said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted June 07, 2014 - 12:48 PM
:iagree:
I also always use straight 30 weight.
Ben W.
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted June 07, 2014 - 02:49 PM
Strait 30 w in everything i prefer pennsoil
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 07, 2014 - 04:35 PM
Amsoil makes a synthetic oil that is rated for use where 30w was specified. I have some of it but haven't changed it into my 314 or 317 so I can't tell you how it works.
#7 Traill95 ONLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted June 07, 2014 - 07:32 PM
Straight 30 Weight.   :thumbs:
#8 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted June 08, 2014 - 05:30 AM
Of the two engines I put synthetic into, both blew up. One being a K341! I won't use synthetic oil again!
  • LilysDad and propane1 have said thanks
