1256-01 Restoration
#121
OFFLINE
Posted July 19, 2011 - 09:29 PM
#122
ONLINE
Posted July 20, 2011 - 07:19 AM
What color did you use for the green?
#123
OFFLINE
Posted July 22, 2011 - 09:58 PM
Any Thoughts?
#124
OFFLINE
Posted July 22, 2011 - 10:01 PM
Looking Good
Valspar "Lucious Green"
looked to be a perfect match to the deck, not as attention grabing as your yellow (lol) but it gets the job done
#125
OFFLINE
Posted July 23, 2011 - 09:25 AM
At some point the pressure built up in the block and popped the dipstick out of the tube. It never hesitated or anything. In the garage I can reproduce the symptom at high rpm.
Any Thoughts?
I've seen that a few times. ....We would bend the dipstick slightly to increase the tension if your dipstick has the "accordian" folds.
I don't know if you have a tach, but you do want to keep the engine speed down to 3200-3400 rpm for durability.
#126
OFFLINE
Posted July 23, 2011 - 09:57 AM
I was looking into a tach/hour meter. I guess i'll pull the trigger on that one.
#127
OFFLINE
Posted July 23, 2011 - 02:17 PM
Thanks Bruce,
You don't need a built-in tach. ....We always used the vibratory-type tach (sirometer) sold by B&S (#19200) and Tecumseh (#670156 ?) in our shop. .....I had the opportunity to check their accuracy against an electronic tach, and the vibratory type were very accurate.
- Texas Deere and Horse said thank you
#128
OFFLINE
Posted September 12, 2011 - 08:16 PM
So today I got the twist lock throttle cable working so I could hold RPM's without holding the throttle. Took it for a spin and noticed the choke cable kept floating. Upon inspection the piece that holds the cables broke.
Could somebody give me pics of there setup. I haven't found the part number for this bracket yet but i'll keep trying.
Edited by Bigdaddydon, September 12, 2011 - 08:29 PM.
#129
ONLINE
Posted September 12, 2011 - 08:41 PM
I'll see if I can get some pics up tomorrow
#130
OFFLINE
#131
OFFLINE
Posted September 14, 2011 - 09:08 AM
Looks like it uses the crankcase cover bolt for mounting?
Yes, that is correct.
#132
ONLINE
Posted September 14, 2011 - 07:25 PM
I found some pics of what looks to be original. It looks like angle iron drilled to spec. Since the one I had was homemade I guess it won't hurt to make this one. Looks like it uses the crankcase cover bolt for mounting?
Sorry, I forgot all about locating a picture for you!
The funny thing is thats my TR-10D you got a pic of LOL
#133
OFFLINE
#134
OFFLINE
Posted September 16, 2011 - 04:21 AM
#135
ONLINE
Posted September 16, 2011 - 06:31 AM
You can center your steering wheel by adjusting the tie rod and drag link ends.
