1256-01 Restoration
135 replies to this topic
#61 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted February 13, 2011 - 11:34 PM
Ok, This will get me caught up, after this my posts will be "live".
First I did some hi-light painting. I know its not original but I like the idea of some accent color
I wanted to put some of the heat sheilds on before I got to far, those bottom bolts are tough to get to. I saw the fuel line ran behind the flywheel and shroud so I put it in while it was easy.
Then it was time to get the tires back on it so I could roll it out of the way and let my wife back in the garage
That is how it sits right now. I am working on the dash tower so I can get it installed and then rewire it and start it up again. Also I will be sand blasting the rest of the tin, priming sanding and painting. I will try to post pics as it goes along so I do not get behind and my questions will be more timely.
Thanks to all for the kind words. So far this has really been a blast.
Edited by Bigdaddydon, February 13, 2011 - 11:38 PM.
pic location
#62 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 13, 2011 - 11:39 PM
I really like the accent paining. Thanks for the pics.
#63 NUTNDUN OFFLINE
  • 10456 Thanks
  • 15622 posts
Posted February 14, 2011 - 05:31 AM
The Bolens is looking really nice Don.
I do like the accent color. I almost painted the motor on dad's 1053 black to help break up all of the white but decided not to. You are definitely moving along on your project :thumbs:
#64 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted February 14, 2011 - 06:05 AM
WOW
That is looking really Nice! :dancingbanana:
What I usually do on those bottom shroud bolts is cut a slot in the metal and then all you have to do is loosen the bolt instead of take it out all the time
  • Bigdaddydon said thank you
#65 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted February 14, 2011 - 08:54 AM
WOW
Great idea Brian, consider it done.
#66 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted February 14, 2011 - 01:13 PM
Yeah, it works great. Since its on the bottom you will never see it anyway.
#67 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted February 14, 2011 - 03:05 PM
Are those drive and PTO belts the Oregon blue Kevlar Belts?
#68 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted February 14, 2011 - 03:07 PM
Boy is that ever coming along,looks really nice so far.
#69 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted February 14, 2011 - 03:37 PM
Yes they are. I got them from jestin at tube frame restorations. Have you used them. What do you think?
  • plowman2 said thank you
#70 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted February 14, 2011 - 03:38 PM
I like them alot
So far they are the closest quality to the original Bolens belts.
#71 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 14, 2011 - 07:36 PM
my belts are original on my 1050 an it needs some new ones BAD. where did you get them?
#72 Bill56 OFFLINE
  • 844 Thanks
  • 2179 posts
Posted February 14, 2011 - 07:44 PM
Great job! You're making a lot of progress.
#73 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted February 14, 2011 - 08:43 PM
my local mower shop carries the oregon belts but if you cant get them locally get them at tubeframes.com
#74 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 14, 2011 - 09:37 PM
my tsc had them blue belts but i dont know if they have the size bor the bolens
#75 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted February 21, 2011 - 04:10 PM
Well progress is slow. The seat came in last week. I really like the idea he had but the workmanship is disappointing. I'll save those pics for later in the build. The decals from maplehunter came in. They look great.
I don't need the BOLENS decals in the first pic and I don't think I need the round Huskyman.
Any ideas on how to get my serial number and model number in the ID tag.
Still need pin stripe, although I may paint that on, any thoughts on painting the pin stripe. The other decal I need id the Hydrostatic Drive decal for the skirts. I'll have to drop a line to Carrie at Maplehunter to see what can be done.
