Wanted
Wheel Horse Commando 800 Pto Clutch
2 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted June 05, 2014 - 07:13 PM
Checking to see if anybody has a spare PTO clutch that will work for a Commando 800? Mainly what we need is the inner pulley closest to the engine and also the disc which has the clutch lining riveted to it. Working on one for dad's one friend and the clutch liner has the rivets but they were never set and they are way too short. On the inner pulley the one bolt hole is broken out.
#2 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted June 06, 2014 - 04:33 AM
Looks like the inner pulley drives the transmission belt and part number 101875. It is not part of the pto clutch. See if you can open this
http://www.wheelhors...ring-a-5347pdf/
Garry
#3 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted June 06, 2014 - 05:22 AM
I was able to open the file. Looks like it is 14-03 part number 141875 or 101875 that I need. Everything else with the clutch is in decent shape other then needing to rivet the lining back on. Somehow they had the rives just dropped in place which are too short to actually rivet in and it worked. I don't really want to put it back together like that.
