Brought A Ford 120 Home Tonight.
25 replies to this topic
#16 IslandFordguy OFFLINE
IslandFordguy
  • 19 Thanks
  • 57 posts
Posted June 05, 2014 - 12:41 PM
Just a guess but 69 or 70? Electric PTO came in 69 I think. was lever before that. Could be wrong tho...
  • IamSherwood and propane1 have said thanks
#17 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 05, 2014 - 02:06 PM
up to and including '71 I think since the openside LGTs are '72-'76, this one here is also electric pto so the two tractors are nearly identical, mines a little worse for wear tho... lol
#18 propane1 ONLINE
propane1
  • 9,135 Thanks
  • 4,280 posts
Posted June 05, 2014 - 06:22 PM
Thought it was 1971 to 1976 open side then 1977 to 1983 closed side. Noel
#19 KennyP ONLINE
  • 40,154 Thanks
  • 46,773 posts
Posted June 05, 2014 - 07:51 PM
!972 -1976 for open side! This is some earlier than that!
  • propane1 said thank you
#20 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 05, 2014 - 08:08 PM
Just need to check the engine date, tractor will be about 3-4 months newer than that, im on my phone so dont have the Kohler links with me but GTT probably has copies in the manuals section.
Tractordata.com shows up to '71 for A Ford 120, 72-83 for LGT series
#21 IamSherwood OFFLINE
  • 8,395 Thanks
Posted June 05, 2014 - 10:12 PM
I got the hydro linkage freed up, carb cleaned and back together tonight.
Took it for a ride. :dancingbanana:
It needs some adjustment. Not enough forward speed, and too much reverse.
The engine is running good and strong. When I throw it from full reverse into
forward, it spins up the gravel, and the governor does it's job. The engine
does blow some crap out of the exhaust when I do that, but I guess that
should be expected. It got new fuel line, valve and filter. Next, I'll look at the
electric PTO.
  • grand, KennyP, sacsr and 1 other said thanks
#22 IamSherwood OFFLINE
  • 8,395 Thanks
Posted June 07, 2014 - 06:10 AM
? Am I correct here?
To adjust the hydro linkage, the rectangular metal block (that I have the square headed set screw
removed from) needs to be rotated on the shaft to the desired position?
Also, Electric PTO is working.
#23 KennyP ONLINE
  • 40,154 Thanks
  • 46,773 posts
Posted June 07, 2014 - 07:03 AM
Haven't needed to do that as yet, Will. But it may work. Just be sure you keep neutral in the shifter slot. Maybe have neutral toward the rear of the slot? That linkage between the two blocks could be used for minute adjustments.
  • IamSherwood said thank you
#24 IamSherwood OFFLINE
  • 8,395 Thanks
Posted June 09, 2014 - 09:27 PM
I couldn't get that block freed up, so I removed the whole
shift lever and bracket. I then discovered that the lever was bent
where it's flattened and welded to the shaft. Someone must have
tried to force it. Straightened it out, reinstalled, and all is good.
  • KennyP and TomLGT195 have said thanks
#25 grand OFFLINE
grand
  • 2,098 Thanks
  • 2,031 posts
Posted June 11, 2014 - 10:14 AM
Will,I'm glad to see you are making good progress on your latest project. The sputtering you described earlier as Phlaterphizzzpuff, I never knew how to spell. Our folks here on the site are being very helpful which is what the site is all about. Looking forward to watching your progress.
Edited by grand, June 11, 2014 - 11:11 AM.
  • TomLGT195 said thank you
#26 cherokee140 OFFLINE
cherokee140
  • 18 Thanks
  • 20 posts
Posted June 24, 2014 - 09:27 AM
That engine sounds great....nice and smooth.
