1952 David Bradley 57560
8 replies to this topic
#1 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 04, 2014 - 01:00 PM
After working on and off for two months, my "Super Power' is completed. I was lucky in that I found a complete and running tractor. I am originally from Illinois and would frequent the Bradley, IL area often so a piece of history was needed. The major item on the tractor that needed work was the clutch. Other than that, I basically stripped and then greased, lubed, and painted everything. Where I could I used stainless steel hardware for a little "bling." I have two acres of trees so no room for a garden plot which means it will probably sit for the most part. Now to find my second one!
DSCF9731.JPG DSCF9745.JPG DSCF9845.JPG DSCF9847.JPG DSCF9850.JPG DSCF9849.JPG DSCF9854.JPG DSCF9855.JPG
Edited by shallowwatersailor, June 04, 2014 - 06:19 PM.
  • Alc, trowel, Traill95 and 4 others have said thanks
#2 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 04, 2014 - 03:18 PM
Nice job! What red did you use?
  • shallowwatersailor said thank you
#3 HANKG OFFLINE
HANKG
  • 6,591 Thanks
  • 3,528 posts
Posted June 04, 2014 - 05:55 PM
NICE TRACTOR GOOD JOB
#4 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 04, 2014 - 06:21 PM
I used Rustoleum Safety Red and Fern Green. It is a bit brighter than my Wheel Horses so a nice change.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 04, 2014 - 06:34 PM
You did a very nice job, looks great.
#6 Likesspace OFFLINE
Likesspace
  • 190 Thanks
  • 122 posts
Posted June 04, 2014 - 07:42 PM
Great job on the tractor! Now I wish that I would have thought of the s.s. hardware. Looks fantastic!
#7 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 04, 2014 - 07:57 PM
I try to use stainless steel hardware when putting tractors back together were strength is not an issue. It prevents the "rust trail" below fasteners.
  • Alc and trowel have said thanks
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 04, 2014 - 08:10 PM
Very nice!
Ben W.
  • trowel said thank you
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 04, 2014 - 08:38 PM
no reason to let it sit around, build your self a hauling cart and ride around behind it.
