Recent Bolens Finds
30 replies to this topic
#16 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted June 04, 2014 - 01:49 PM
Are the handles on this early Gardener like the ones on the DQ? I can't really tell from the pictures. It looks to have the cast rims.
yea same style handle bars an has the older style tag as well I believe it's a model b6 bolens it doesn't actually say gardener on the gas tank like the newer ones
#17 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 04, 2014 - 02:01 PM
When you get the Gardener  can you give me some better pictures of the grass divider on that Unisickle?
The one for my power ho is missing and was going to make one out of sheet metal.
#18 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted June 04, 2014 - 02:06 PM
sure can the one on this could be larger than the power ho is but I will let you know
#19 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6034 Thanks
  • 2244 posts
Posted June 04, 2014 - 03:46 PM
I will for sure. I hope you can make it to Portland this year There is going to be a lot of ridemasters down there I'm thinking upwards of 20 or more now
I'm certainly going to try.   It all depends on whether or not we are able to get moved in time.
I would like to meet both you and Hank Watkins .   I'm sure other people that I've talked with on GT Talk will be there and it would be nice to meet them also.
If we can make it, I should be able to bring at least one of my Ridemasters and the Bean Cutler.
  • gunstuff1000 said thank you
#20 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted June 04, 2014 - 06:14 PM
Is that suppose to have the sheet metal divider or the cast aluminum one on the sickle its self? I could post some pics of one of the sheet metal ones I have.
#21 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 04, 2014 - 06:36 PM
Yes, Just the sheet metal  the same one as in Aaron's picture
#22 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted June 04, 2014 - 07:40 PM
Here's what I have for the shanks. 4 are in good shape and there might be 2 decent enough to weld up a little to make work.
Here's a few pics of the divider. 8" tall at the back, 11 3/8" along the bottom and about 14 1/2" down the top side. The front has some fancy stamp work done if you can see what I mean from the pics. If all else fails I can try and make a copy of one side out of paper and send it to you.
IMG_20140604_192030_190.jpg IMG_20140604_192107_787.jpg IMG_20140604_192558_230.jpg IMG_20140604_192638_140.jpg IMG_20140604_192709_660.jpg IMG_20140604_192818_819.jpg
  • Bolens 1000 said thank you
#23 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 04, 2014 - 07:50 PM
Those duck feet were also made by planet Jr.
Thanks for the photos of the Divider, I'll play around with the sheetmetal one of these days and see how things turn out. Too many projects going on at one time again! I need to focus on 1 piece of equipment at a time instead if my 30 projects going on at the same time :D
#24 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted June 04, 2014 - 08:01 PM
I remember seeing the duck feet on a simplicity once. Must have been common back then.
I know what you mean. I also have to many irons in the fire.
#25 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 04, 2014 - 08:04 PM
If you ever restore that Unisickle , I have a NOS Decal for it we can get copy's of. You can see the faded outline of where it is on that deflector.
  • Nato77 and gunstuff1000 have said thanks
#26 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted June 05, 2014 - 09:50 AM
. It looks really cool when it's mounted on the tractor. The ridemaster it came on a friend of mine bought that the guy we got it from is convinced that the tractor was taken out the back door of the bolens factory This came from port washington Wisconsin He was telling us that a lot of stuff like that was happening around that area he had a lot of stories to tell us that's for sure There was several other brackets an pieces that we have no idea what they are for an they have bolens paint on them I'm speculating that maybe it's pieces to the sprayer attachment but I'm not convinced yet
Sounds like Jonny Cashe's cadilac... :rolling:
#27 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted June 05, 2014 - 10:19 PM
This cultivator has turned into a lot of work i was hoping for a quick clean up an re-paint after taking the cultivator tools off I are that it has spent some time probably in the rain things are rusty under the nuts an washers now im having to blast things an start over On the bright side the id tag is like brand new looking on this Im afraid I'm going to have a hard time finding a exact match on the wheels but I will keep searching
#28 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted June 05, 2014 - 10:44 PM
Aren't they the same as the cultivators on the Power Hos and Versa matics?
#29 gunstuff1000 OFFLINE
gunstuff1000
  • 957 Thanks
  • 564 posts
Posted June 05, 2014 - 10:48 PM
same size but the tire is a different style
#30 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted June 05, 2014 - 11:19 PM
Could you take a few pics of one? What is different the rim of tire?
