Need Help With Ford Lgt
4 replies to this topic
#1 Howard5.9 OFFLINE
Howard5.9
  • 2 Thanks
  • 1 posts
Posted June 03, 2014 - 12:59 PM
I have an old Ford LGT 145 that I'm trying to put the mower deck back on and i can't find any pictures of how the brackets go together
  • tinbender7 and propane1 have said thanks
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,137 Thanks
  • 5,092 posts
Posted June 03, 2014 - 01:23 PM
Welcome to the forum. I moved your post over here to the Ford forum for better exposure. I'm sure one of the Ford guys will be along to help you out. I think there should be a manual for it in the manual section.
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,095 Thanks
  • 2,925 posts
Posted June 03, 2014 - 03:11 PM
:welcometogttalk:  which model , open side or closed?  a pic would be helpful ,which brackets? Tom
  • propane1 said thank you
#4 boyscout862 OFFLINE
  • 13,684 Thanks
  • 9,473 posts
Posted June 04, 2014 - 04:29 AM
Welcome to GTT. Check out our Manuals Section for 3 free downloads per day. Pics can help us to help you. BTW that is a really good tractor. Good Luck, Rick
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 04, 2014 - 04:51 AM
Open or close sided they both attach and mount to the tractors the same. Only diff is the actual scissor profile. The actions and mountings are identical. A deck off a 1972 rig will slip right under a 1983 model as long as it is not the "LT" or 195 models.
Do you have the scissor frame on it ? And if so it should be spring loaded to hold it up regauardless of lever position with out a deck on it.
If you dont have this frame you are not going mount a deck on.....
  • KennyP, boyscout862 and TomLGT195 have said thanks
