Will Cleaning Up The Carbon Make My Engine Run Better
5 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted June 01, 2014 - 10:28 PM
will it give it a boost of power
  • 14,862 Thanks
  • 15,511 posts
Posted June 01, 2014 - 11:20 PM
It should hake it run stronger, cooler and better ..
#3 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted June 01, 2014 - 11:42 PM
Can't hurt. Just be sure to true up the head before replacing the gasket.
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,860 Thanks
  • 10,039 posts
Posted June 02, 2014 - 07:16 AM
No! It will lower the compression. You'll lose about 1/2 a horsepower. On the other hand, you won't have that annoying valve noise anymore!
#5 JDBrian OFFLINE
  • 9,640 Thanks
  • 14,156 posts
Posted June 02, 2014 - 08:30 AM
I had a lot of blowby in a K321 and when the carbon was removed it fixed that issue. There was enough carbon in there to interfere with the piston at the top of it's travel. I don't think carbon is the best way to increase compression ratio. It has some negative effects.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,860 Thanks
  • 10,039 posts
Posted June 02, 2014 - 11:28 AM
  • Dieselcubmike and T Guiles have said thanks
