Almost Finished "super Power"
10 replies to this topic
#1 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 01, 2014 - 07:14 PM
Normally I am working on my Wheel Horses but picked up this 917.57560 in April. I decided to repaint it while cleaning and re-greasing everything. I got it started today and have the hood ready to go on, but I am having a problem with the hood pins. The tractor has the optional reverser but does not have the longer pin. Is there an alternate to use? It still needs some touchup.
  • Alc, CRFarnsworth, New.Canadian.DB.Owner and 2 others have said thanks
#2 petrj6 OFFLINE
petrj6
  • 4097 Thanks
  • 2370 posts
Posted June 01, 2014 - 07:29 PM
   Looks awesome!!!!!
#3 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 01, 2014 - 08:05 PM
That is really looking good! Thanks for sharing!
#4 New.Canadian.DB.Owner OFFLINE
  • 2568 Thanks
  • 1631 posts
Posted June 01, 2014 - 08:07 PM
Depends if you are looking for OEM or functional.  I built a set of pins from some round rod & washers. I cut the rod to length, welded on the washers & drilled the holes for the retaining clips.  Quick & simple.
Edited by New.Canadian.DB.Owner, June 01, 2014 - 08:08 PM.
  • shallowwatersailor, Alc, trowel and 1 other said thanks
#5 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 01, 2014 - 08:15 PM
Thanks! I am looking for functional.
#6 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted June 01, 2014 - 08:55 PM
I'm curious.  What are those tires?  I thought at first they were just worn by looking at the tread, but I see by the sidewall they look new(er).  I need some shoes for my DB's, that's why I ask.
Ben W.
#7 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 01, 2014 - 09:29 PM
Ben W.
They are old Mansfield Mud-Snow 6.50-16 directional tires. They must have tubes inside as one tire has a huge crack in the sidewall. But they seem to fit the era and are holding air so I plan to leave them on. I applied Miller tire paint after I first bought it  but need to apply a second coat when the tractor is finished.
  • Alc, New.Canadian.DB.Owner and superaben have said thanks
#8 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 02, 2014 - 04:39 AM
I scrapped out an old gas grill but kept the pins that hold the wheels on it. They are almost identical to the hood pins, just a little longer so they can be cut to length. I'll try to post a picture later.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted June 02, 2014 - 08:19 PM
you can also use a long rivet., just the head will be a little smaller.
#10 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted June 04, 2014 - 12:37 PM
Here is what I came up with. It is a 1/4-20 x 3" carriage bolt using 1/4-20 well nut and acorn nut on the outside. It will save trying to reach under the hood for the cotter pin. The hood stay unfortunately doesn't  work as is. I am going to play with the left side and maybe shorten the well nut.
Edited by shallowwatersailor, June 04, 2014 - 05:52 PM.
#11 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 04, 2014 - 03:21 PM
That should do it. Good idea.
