Relay Troubles
1 reply to this topic
#1 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted June 01, 2014 - 02:52 PM
     I've got a 74 MTD 990. I've put 2 relays on in the past year. Now this one quit working! If you jump the terminals it turns over. I'm using the standard 4 terminal model from TSC. This one went out after trailering it about 30 miles. Any clues?
#2 VTXrider OFFLINE
VTXrider
  • 544 Thanks
  • 396 posts
Posted June 01, 2014 - 04:07 PM
Assuming you are referring to the starter solenoid. Your are having a string of bad units. I use the the original style with 3 terminals. The mounting bolts ground it. http://www.amazon.co...5/dp/B001ULPJKE
I have also used the Ford starter solenoids. http://www.amazon.co...y/dp/B004PKC1YO
like you are using, famous for failing often.
Either will work. I would quit using the TSC unit.
Edited by VTXrider, June 01, 2014 - 04:09 PM.
