First Real Problem With The 129
4 replies to this topic
#1 Clubmike OFFLINE
Clubmike
  • 23 Thanks
  • 18 posts
Posted June 01, 2014 - 12:13 PM
I have a cub cadet 1974 129
I cannot seem to shift it into forward or reverse. The handle was a little loose so I tightened up the set screw so it is nice and tight. I pulled off the inspection plate above the linkage, I do not see anything jamming up. The tractor seems to be in neutral, when I start it it does not move.
I did drive and mow with this tractor a few days ago. It seemed like the handle was a little sloppy then and 1 time it did not go into reverse, but I moved the handle around and it worked.
Now I cannot get it into forward or reverse.
Does the tractor have to be started to move this lever?
Does anyone have any idea of where I should start.
I did check the hydraulic level, it did not pour out the filler plug but I see it on my little finger when I stick it in.
Here is a short video.
  • Attached File  2015.MPG   7.24MB   30 downloads
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted June 01, 2014 - 01:15 PM
It looks like the brake is depressed which puts it in neutral and locks the lever. I would check the brake pedal and it's linkage.
Geno
  • KennyP, tinbender7 and Clubmike have said thanks
#3 Clubmike OFFLINE
Clubmike
  • 23 Thanks
  • 18 posts
Posted June 01, 2014 - 01:24 PM
That is exactly what it was. Now I feel silly.
However, I am very happy I can mow some more today.
Thanks for your help.
Mike
  • tinbender7 said thank you
#4 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted June 02, 2014 - 11:45 PM
Don't feel silly. Sometimes the simplest things on a different tractor that your not used to can throw you a curve ball. At least it was a simple fix, and didn't cost you a dime.
Always a good idea to familiarize yourself with a tractor by reading the owners manual, wouldn't hurt.
#5 Clubmike OFFLINE
Clubmike
  • 23 Thanks
  • 18 posts
Posted June 04, 2014 - 08:40 AM
It is funny you said that, I actually have a printed manual, however I thought I could figure it out. I have since read the manual and learned some good stuff.
