White 1655
5 replies to this topic
#1 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted June 01, 2014 - 11:54 AM
So after the pull yesterday a very good friend of ours knows into any garden tractor to play with so he told me he had a white but wasn't able to tell me everything about it so I went and looked at it. Turns out its a white yardboss 1655. Everything is there except the 3 point lift arms which is no big deal I can always make them if I have to. My main thing was that it needed to have a mower deck and had to run. Well it does run. sort of. He said it would need an electric fuel pump for it to stay running since its not a gravity fed carb. Says there's a lot of blow by(just my luck) but it does start and fire but shuts back off. I forgot to grab pictures :( sorry guys! SO with that being said, should I have the motor rebuild or replaced? Its a close resemblance of my two 990's I have but set up just a little differently. Anything I should look out for? anything to be aware of?
#2 VTXrider ONLINE
VTXrider
  • 535 Thanks
  • 392 posts
Posted June 01, 2014 - 12:28 PM
If it is like JD212's 1655, there would be very few similar parts.
http://gardentractor...rd-boss-gt1655/
There are many posts on GTT about the 1655.
Edited by VTXrider, June 01, 2014 - 12:28 PM.
  • Dieselcubmike said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 01, 2014 - 05:16 PM
That White is on my list of desired GTs. Good luck they make up into a real nicce working tractor.
#4 VTXrider ONLINE
VTXrider
  • 535 Thanks
  • 392 posts
Posted June 02, 2014 - 06:53 AM
Reference to the manuals here. The links from Blacksmithman are still good.
http://www.mytractor...ead.php?t=43411
Edited by VTXrider, June 02, 2014 - 07:07 AM.
#5 glgrumpy ONLINE
  • 8,815 Thanks
  • 8,014 posts
Posted June 02, 2014 - 12:45 PM
Ummm! NO pix here!  What engine in this thing? I had late model bigger one with V-twin Vanguard 20hp.  It had a fuel shut-off on it to cut the flow when key is off to shut down engine. Think the pump was just a plastic vacumn operated one on the engine somewhere, like on the valve cover area? Can buy a Briggs generic one at most shops that looks diff, but works same. I also owned similar engine in a Speedex, that didn't shut off with key right away, the shut-off would let it run about 10 seconds and auto shut-off as gas is closed off. Not sure why it did that. Guess no ignition to cut off on these?  These are very similar to 990's, but quite a bit different. I like the looks of Yard Boss's, but can't see yours to compare, ha!
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted June 03, 2014 - 08:25 PM
It has a 16hp briggs flathead opposed twin on it. Not the ohv that I wanted :( but its something different and it actually has a mower deck on it. It seems when I pick tractors up they either have no motor, no mower deck, or all of the above. Im getting it Friday hopefully all I did was give my friend a deposit to hold it for me
