Split In Half Piston !
7 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,472 Thanks
  • 4,405 posts
Posted June 01, 2014 - 10:05 AM
Well, I found out first hand that Kohler pistons split in half.  I was reading a post about one or two weeks ago on here about pistons splitting and mentioned that I never heard that before.  I know now.  So have to get it apart and see what other damage was done.  Have another 14 engine, so I will see if it is any good and maybe fix it up and put it in to replace the 12, then fix 12 for spare engine.  No painting on this project. More of a rush to get it back into service. 15% more power from 12 to 14, said on weekend freedom machines web site.  Noel
  • MH81, boyscout862 and TomLGT195 have said thanks
#2 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 01, 2014 - 10:45 AM
Overheated and split at the oil ring?
  • propane1 said thank you
#3 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted June 01, 2014 - 10:55 AM
Please post pics. I have not heard of splitting a piston in half.
Geno
  • boyscout862 and propane1 have said thanks
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 01, 2014 - 11:00 AM
Had it happen on 2 stroke motocross bikes, but never on a mower type engine myself.
  • CRFarnsworth and propane1 have said thanks
#5 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted June 01, 2014 - 12:18 PM
Been There!  Rick
#6 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted June 01, 2014 - 01:39 PM
I haven't taken it apart yet, but I believe that is what happened to my 16 HP in the Ford! And it didn't overheat!
#7 propane1 ONLINE
propane1
  • 9,472 Thanks
  • 4,405 posts
Posted June 01, 2014 - 03:25 PM
Not all apart yet, but base is off. Turn it over and you see bottom half moving and not top part.  Parts of oil ring in base.  Will post pictures.  Only was running for 5 minutes and checked oil before starting.  Noel
  • KennyP and bgkid2966 have said thanks
#8 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 01, 2014 - 03:51 PM
Sounds suspiciously like it got too hot, could have been running a bit lean, or the points were a bit off, either can cause a kohler to run hot inside without being very noticable otherwise, and splitting at the oil ring is a pretty common result. Its alot better than having trouble in the bottom end tho, should still be able rebuild it at a reasonable cost.
