Looking For Parts For A Wheel Horse 856
9 replies to this topic
#1 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted May 31, 2014 - 06:04 PM
Just picked up my first wheel horse. Everything so far is good except the keys in the axles have been sheared off. Anyone know where i can find either new or used axles and hubs? Thanx
#2 KennyP ONLINE
  • 38,473 Thanks
  • 45,969 posts
Posted May 31, 2014 - 06:15 PM
:wave: Welcome to the forum! I'll let the WH folk tend to this!
#3 KC9KAS ONLINE
KC9KAS
  • 5,388 Thanks
  • 4,692 posts
Posted May 31, 2014 - 07:05 PM
:welcometogttalk: , and :wewantpics:
I am a WH guy, but can't help with your issue...Maybe contact one of the vendors here.
#4 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted May 31, 2014 - 08:42 PM
I was thinking of welding the hubs to the axles, not sure if that would hold, but thats  if i cant find the parts.
#5 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted June 01, 2014 - 12:06 AM
Don't weld them!
You'll burn off the axel seals!
Just go to your local hardware store and get some woodruff keys.
I think their 3/16"
Joe
#6 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted June 01, 2014 - 12:49 PM
Yes, i know, but too much metal is gone from the hubs, as well as the axle shafts. Maybe they can be repaired? thanx again
#7 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted June 01, 2014 - 03:40 PM
Does anyone know where i can find these parts, cause i am at a loss!!!!
#8 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted June 03, 2014 - 05:14 AM
Took the transmission apart and the shafts are too badly deteriorated and same with the hubs......so now i am thinking of welding the shafts to the hubs and then reinstalling them before the seals go in.  Any comments?
#9 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted June 03, 2014 - 05:27 AM
That's a shame both axle and hubs are bad , is there anyway you could drill through the hub and axle and use a long 1/4" bolt or roll pin ?  I've welded the hubs to an axle of a old 4 wheeler with the same problem , just tacked enough weld to keep it locked on but I didn't go crazy just in case I had to grind off the weld to remove the hub.
#10 batmdcatw OFFLINE
batmdcatw
  • 6 posts
Posted June 04, 2014 - 04:52 PM
Yes, that sounds like a good idea....better than mine, but first i think ill take them to a millright and see what can be done and how costly it will be. Thanx for your input....muchly appreciated.
