Starter drive
12 replies to this topic
#1 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 26, 2011 - 03:11 PM
I have a 1811, and I have been finding in the cold weather, the drive on the starter seems to retract from the flywheel too early, before the engine starts. I have tried using a thinner oil, thinking that it was too heavy, causing too heavy load on the starter. The other thing is, maybe there is a problem with the starter itself. The battery has been tested, and is good. Any input would be highly appreaciated!
Thanks,
Boatiee.
Edited by boatiee, January 27, 2011 - 08:24 AM.
  • 14,866 Thanks
  • 15,512 posts
Posted January 26, 2011 - 03:35 PM
Does the starter seem to spin freely, off the engine or is it drag ,turn slow?
#3 cubman OFFLINE
cubman
  • 33 Thanks
  • 61 posts
Posted January 26, 2011 - 09:06 PM
the starter will spin freely while the ignition is turned on, but the problem is, it's not engaging the flywheel long enough to start the engine. It will turn it 2 or 3 revoulitions, but not any more. If it's warmed up, it'l start fine.
#4 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 27, 2011 - 06:49 AM
The starter will "back off" too early. It will continue to spin freely if you keep the ignition engaged. We took the sparkplugs out and it will turn the engine over without "backing off" with the plugs out (no compression).....
#5 tyler OFFLINE
tyler
  • 57 Thanks
  • 140 posts
Posted January 27, 2011 - 07:22 AM
i think it's a weak starter ready to die. my old tractor did the same thing, i switched starters and fixed the problem
#6 MH81 OFFLINE
Posted January 27, 2011 - 08:05 AM
I agree. That or low voltage/current. The battery was checked, so that leaves the wires or solenoid if that's the problem.
I have rebuilt a couple of bendix units over the years & this may be simple as a weak spring, but changing the starter would test for that & a bad starter. One quick thought, check to make sure it's mounts are clean & tight... that's where it gets ground.
#7 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 27, 2011 - 08:06 AM
I took it in to a starter guy and he refurbished it and said it is in "new" condition..... ???
#8 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 27, 2011 - 08:07 AM
Can anyone tell me the cheapest options for buying a starter online??
#9 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 27, 2011 - 08:14 AM
I don't think he did anything to the drive though.....
#10 MH81 OFFLINE
Posted January 27, 2011 - 08:15 AM
Before you do that, ck the wiring one more time, may find a cheaper solution to the problem.
Is the rebuild still under any kind of warranty?
#11 boatiee OFFLINE
boatiee
  • 1 Thanks
  • 9 posts
Posted January 27, 2011 - 08:20 AM
I called the guy and he suggested bypassing the wiring using jumper cables, so that is the next step. He said he might have a drive for it. The funny thing about this is that when the tractor has been running for a bit, and you shut it off, it will start with no problems....
#12 massey driver OFFLINE
massey driver
  • 1,484 Thanks
  • 1,592 posts
Posted January 27, 2011 - 08:27 AM
I have the same problem with mine when it's cold out.It's the bendix spring being to weak.As soon as the motor fires it kicks the starter out,even though the motor doesn't start.When the motor is warm and in the summer there's no problem.In the cold weather when I'am trying to start the motor , it fire's once then the drive kicks out,if it would stay engaged I'am sure I'd have a easier time starting the motor.The tractor is usually kept inside in the winter so I haven't really been to concerned about it not starting.On occasion it's been out in the cold and thats when I notice the problem.So yeah it needs a stronger bendix [starter drive spring] Larry
#13 Alc ONLINE
  • 7,132 Thanks
  • 7,533 posts
Posted January 27, 2011 - 09:25 AM
Had a problem like yours , on the JD 318 , thaought the starter was bad, even checked and had 12volts at the starter stud, ,started taking covers and stuff off , until I got to the ground wire on the head , Oh NO , bad connection , see I had 12volts from the neg battery post to the starter stud but if I would have checked the ground ( starter case ) to the starter stud I wouldn't have had 12 volts. live and learn .
