Bolens H16 Refresh
33 replies to this topic
#16 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted July 25, 2014 - 12:01 AM
I agree good looking tires, coming along nicely.
#17 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted July 26, 2014 - 08:21 PM
Starting to look like a tractor
  • blackjackjakexxix and Sawdust have said thanks
#18 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 13, 2014 - 06:08 PM
So this has been on the back burner. But it's time for an update my 1050 died again and im sick of trying to locate used motors for it so since the h16 needed the front axle and support i robbed the 1050 for it.
So i swapped the front end parts on sunday, I adjusted the carb. I also swapped muffler with the one i had but it must be bad as it chokes the engine out at high RPMs. I also put a seat on it finally im not happy with the fitment on the factor seat support so im going to drill new holes so i can move it closer as right now it's to far back. I also made a battery bracket about time i stopped being lazy.
#19 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 13, 2014 - 06:14 PM
Looking good!
#20 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 13, 2014 - 06:20 PM
Looking good!
I forgot to mention i put new drive and PTO belts on from you brian.
  • Bolens 1000 said thank you
#21 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 13, 2014 - 06:30 PM
Those should last you a long time!
Whats up with the 1050?
#22 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 13, 2014 - 06:36 PM
Between the motor on it started smoking and knocking real bad and the gears being ground very bad it's not worth saving sadly. The re paint it has was very good at hiding the very hard life it had. I also prefer the hydro better i would like to find a 1225 or 1256 one day.
#23 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 15, 2014 - 12:45 PM
So i re adjusted the card to the factory muffler and now the OHV 16 motor runs great no smoke or anything. I installed a new plastic bushing for the hydro drive pedal.
I also threw my 38" deck on and mulched the leaves in my lawn i really love this H16 plenty of power and the hydro is quit and smooth and it makes mowing in my yard so much easier to do. The Carlise tires are an excellent choice with the hills i mow they never lost traction and and didn't tear the lawn up either.
DSC_0297.JPG DSC_0298.JPG DSC_0299.JPG DSC_0301.JPG DSC_0302.JPG DSC_0303.JPG DSC_0304.JPG DSC_0305.JPG
Edited by JohnWR, October 15, 2014 - 12:46 PM.
#24 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 15, 2014 - 03:36 PM
Looks like your back up and running. :thumbs:
#25 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 15, 2014 - 05:01 PM
It's getting there i have a very nice factory muffler coming from Rick and i need to add tail lights and fix the seating position and then it's time to get it's blower back together.
  • Bolens 1000 and blackjackjakexxix have said thanks
#26 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 19, 2014 - 05:54 PM
Got my muffler from Rick it had a few holes that needed to be patched and that turned into a issue as it turned out to be a really thin muffler in general.
  • Bolens 1000, blackjackjakexxix and Sawdust have said thanks
#27 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 19, 2014 - 06:04 PM
You know after looking at these pics, it appears the cub cadet muffler which costs around $30  new would be a direct fit for this!
  • Sawdust and icecream4070 have said thanks
#28 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted October 19, 2014 - 06:10 PM
Indeed they could i actually bought one of those as well then rick told be he had this one for 15 Bucks so i decided to give it a try.
The only Issue's with the cub cadet mufflers are the front bracket needs to come off. And for the H16 the exhaust inlet is far too short it needs to be a few inches longer. If you had a torch you could also heat and bend the bracket for the muffler so you did need to extend the inlet on the muffler.
#29 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted October 19, 2014 - 09:39 PM
Sorry John,didn't relies it was that thin,I should have removed the shield and looked a little better,it did have a very nice outer shield,looks like you did  a nice job fixing it,nice to have an original looking muffler when your going to all that work
#30 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted October 19, 2014 - 10:09 PM
John the PO of my H16 put a Cub muffler on mine & it is too short. I was thinking of maybe extending the tip with a piece of tubing to get me thru & past the bracket. In spite of the surface rust it appears to be a new muffler. He also put a Cub seat on it too :(
